Need Seat repaired/repalced on Branson 4820C
   / Need Seat repaired/repalced on Branson 4820C #11
Looking at just the suspension, the bolt pattern on the base plate is 4.5 x 8" (probably in centimeters) but this is the real measurement for what is needed at the bottom of the suspension or a whole seat. Replacing the handle may not be an option, because I cant figure out how to reset the spring tension to reinstall a new one? Thoughts and thanks to everyone helping!!!
Couldn't you just reset spring tension via trial & error? I dunno for sure but it seems like that is possible to me.
   / Need Seat repaired/repalced on Branson 4820C #12
The only thing you have mentioned as being broken is the adjustment knob and/or the pin that secures it. Is something else broken? Have the springs detached?
Otherwise, why can't you put on a new knob of sorts, and tighten it down the rate of tension you desire?
Resetting 300lb springs and putting your fingers inside the suspension sounds like a great way to lose some fingers. I don’t have a setup to make this happen. Plus I would love to find a replacement instead of the $$$$$ Branson seat.
   / Need Seat repaired/repalced on Branson 4820C #14
   / Need Seat repaired/repalced on Branson 4820C #16
So the springs have become disconnected? If you loosen the adjusting bolt all the way, might you be able to reconnect the springs?
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
FAKE (A52472)
FAKE (A52472)
FAKE (A52472)
FAKE (A52472)
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
