Need Rotary Cutter advice
   / Need Rotary Cutter advice #11
agree 6' is a good match. personally, i'd err to at least a medium duty. when looking at models, judge by weight. my Rhino 8' twin is excellent. in the long run, don't think you'd be satisfied with a light duty to save a few dollars. regards
   / Need Rotary Cutter advice #12
You asked, so my opinion is BushHog and Rhino. Woods apparently makes a great machine also, but I don't have any experience with them.
My personal experience is:
BushHog is well made and parts are readily available.
Rhino is very well made, but parts are typically harder to come by locally(in my area) but are readily available online (German-Bliss)
Howse- never did any thing to it but abuse it and put grease in the gearbox when the output shaft seal started leaking. I was hard on it then gave it to my brother, but is still going good.
Titan (now Iron Craft) Great warranty but parts are through dealer only, and then they may not be the correct parts for your machine.
   / Need Rotary Cutter advice #13
Have you been looking on Facebook marketplace for used cutters and just not found any 6' cutters in your area?
   / Need Rotary Cutter advice #14
I agree with some of the comments on the TSC being light duty. Bite the bullet and go with a heavier duty one. Look at the deck thickness, the size of the gearbox, and the frame.
I've owned a couple of Boomers and found them both to be underpowered based on their stated ratings, but I still think your 40hp will handle a 6 ft. I have a 36 hp MF and it handles my 6 ft Modern with no problems, even in tall thick grass and light brush. You didn't mention Modern but if you can find a dealer somewhere reasonably close their galvanized cutters are great. I ran a 6 ft for ten years and it still looked like new. Sold it with one of the boomers because the buyer wanted it badly but I just went straight to the dealer and bought another one. I have to admit they cost a little more but well worth it. Especially if it's going to be stored outside. I've owned heavy duty Rhino, Bushhog, Woods and Modern. All the painted ones had rust problems on the deck. The Modern just keeps going. My two cents, for whatever it's worth.
   / Need Rotary Cutter advice #15
A 5 ft LS at the Ford dealer
@alligatorob do you mean a New Holland Dealer that still has the Ford-New Holland Signage?
I love seeing places that still have the old signage.
   / Need Rotary Cutter advice #16
Just in case you need to see what a "quality" rotary cutter looks like, lol
SR
   / Need Rotary Cutter advice #17
TW20 here.
Rhino | TW20 Series
The 'hidden gems' will seem to jump and find your blades!
Such as railroad ties and then the blade bends into interesting shapes....lol....
Change oil each year. Take clutch apart and clean up on occasion.
Many tractor dealers carry them and will change blades for ya on the cheap.
Well my 4 cents worth...Happy shopping.
   / Need Rotary Cutter advice #18
Be aware that although your tractor is advertised as 40hp, you actually only have 33hp at the PTO, assuming you have HST. In your case, I'd suggest a "truly" medium duty cutter of 5'.
Most brands have light, medium, and heavy duty. The only exception to this that I'm aware of is Brown Manufacturing, their lightest model is a seriously medium duty cutter.
I'd look into:
Brown Manufactuing model 415 Brown Manufacturing Corp | 800.633.8909
Landpride model RCF 2760 Land Pride
Woods model BB600 (NOT BB60). However, Woods changed their model designation and I do not know the current model numbers.
Bush Hog model 295 (they have also changed their model designations, stay away from anything that says "squealer" on it.
You can't go wrong with Brown, and that is my #1 choice. All the other brands have cheap, light duty mowers that are easy to tear up, however, as long as it's truly a medium duty cutter you can't go wrong with any big brands.
If you can buy it at Tractor Supply or other farm stores, stay away from it, it's likely junk on anything more than grass.
Thankfully, Everything Attachments is out of business so you don't have to worry about decoding their terrible naming conventions.
   / Need Rotary Cutter advice #19
Piston. It appears that your Brown cutter has no chain/deflector on the front. Do you experience much "crap" being thrown back at you as you chomp thru that brush?
I'm STILL in the looking stage. Brown seems to be one of the better cutters. I'm also considering a Rhino. I wanted a Rhino TW35 - however at $7300 - they have priced themselves out of my market.
Certainly looks like you have taken on a major land reclamation project.
   / Need Rotary Cutter advice #20
I also suggest the Woods BB72.
But also have a suggestion on what to AVOID .... which I learned the hard way.
I did have a TSC cutter with the angled rear end of the deck. THEY BEND EASILY. When the blades hit the bent corners you'll know it.
MARATHON 20KW GENERATOR (A58216)
MARATHON 20KW...
SKID STEER ATTACHMENT BRUSH WITH BOX (A58216)
SKID STEER...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58216)
WHISPERWATT 220...
New/Unused AGT Industrial SDA-140T Track Loader (A57453)
New/Unused AGT...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
