need parts for planter
   / need parts for planter #1
wango tango
Peoria IL
hey all - i just picked up a 495 planter. it needs a cylinder, and john deere dealer basically said that they didn't come with one, and that you used the 'one that came with the tractor'.
that being said...anyone have any guesses/starting points? sure would be nice to get this working.
also need some plates for seeds...anyone have any?
   / need parts for planter #2
Could not tell you what size cyl would imagine a reg 8" stroke would work. On the seed plates take your whole bottom to your seed guy and see if they can provide you with plastic plates. They should be the same as the 71 flex planter. That is assuming that what you want to plant already coincides whith the hopper bottoms that you have now (ex a corn bottom is not the same as a beat bottom). Plastic plates for these are easy to get though expect the oem metal plates to be $50 - $100 a piece. Good luck
who sells these? assuming lots of places do. could you give me an example of what you mean?
   / need parts for planter #4
wango
Where are you located?
About any farm store would have the cylinders.
Also, sponsor/advertiser Surplus Center will have them.
What are you planning to plant?
wango
i live in peoria, il.
i'm guessing tractor supply would.
i'm planning to plant beans, corn, sunflowers likely. what else can i with this planter?
   / need parts for planter #6
Need to decide what diameter needed.
What tractor?
What load? Have fertilizer boxes?
Peoria's Blain Farm & Fleet will have them too.
What tractor?
no fertilizer boxes. i have a JD 4410. need a rear hydraulic hookup too.
not sure the load....its a pretty small planter all things considered.
anything else i should consider?
   / need parts for planter #9
Those planter's used a 3x8 in cylinder, very common, TSC has them in stock, usually. As far as plates go, try Lincoln Ag. I bought plates a few years ago, I think they are about $14 per plate. These are plastic, they will last for years and not rust.
Lincoln Ag Products
Lincoln Ag Products
alright! thanks a ton.
anyone know how involved and $ is it to put a rear hyd kit on my 4410?
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
