need oring/# for a 431145A1 hyd filter on a case C80 ( canister style filter )
   / need oring/# for a 431145A1 hyd filter on a case C80 ( canister style filter ) #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
As the title states, I have a case C80 tractor. the hyd filter under the running board is a canister style, 431145A1
I have a NH dealer near me that gets me the filter.. but he is hard to deal with.. 30m hold times when you call, and 20-30m wait times in the parts room if you go by.. it's like a 2 man operation? Anyway. ev ery canister filter I have ever ordered has always come with a new oring that goes between the boss and removable canister shell. This one didn't.
I can look up the filter in the NH parts database, but can't find the oring.
Anyone got an oring part number? If it's an active NH part number I guess I can get it from that dealer.. or I can order from a case dealer in another town.
Thanks
   / need oring/# for a 431145A1 hyd filter on a case C80 ( canister style filter ) #2
Try running your search through Messicks Home | Messick's
I ran the search, and found an exploded view showing the gasket separate, part number being 405462R1, but run the search yourself, and make sure that is it. Looks to run $6.83 for the gasket. If you trust NAPA to cross fit it, looks like they run $1.80 there.
We both had the same good idea, and yup, meeesicks has it. I've got one headed to me. I simply don't trust napa to cross it.. :) They thought they could cross the filter but the wrong one came in.
thanks
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2023 Kubota U55-5R1 Mini Excavator (A56435)
2023 Kubota...
Killbros 260 Seed Conveyor (A56435)
Killbros 260 Seed...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
