Snow Blade need new snowplow
/ need new snowplow #1
gravelman
Platinum Member
NH
Kubota 2650
gravelman here..i have a Kubota 2650 looking for a quick attach hydraulic angle snowplow...i believe it could handle up to 7 footer.... any brands suggested?? i like full trip too
/ need new snowplow #2
Your Kubota dealer should be able to help $$$$'s try Fisher & Boss & Curtis dealers.
/ need new snowplow
ok, good leads...thanks much
/ need new snowplow
i do not have a welder but know someone that does... i do have third valve plumbed to the front... thanks
/ need new snowplow #6
Perfect, plows have become stupid expensive and I and a few others here have some P.U. plow build threads if your interested in that route. I have the measurements/angles to build the ssqa.
As there's snow on the ground now, you may not have the time. I bought a "Snow Wolf" brand plow and it's been very tough. The 10,000 pound skid loader it's used on has no mercy on it and after 10-12 years, it's doing just fine. Skid Steer Plows, Skid Steer Snow Tires, Snow Pushers | SnowWolf Plows They have a dealer locator and iirc, Milton Cat is one.
/ need new snowplow #9
Purchased mine from Michigan Iron & equipment Morrice MI..Very stout set up..
/ need new snowplow #10
Or just pull the loader off, drop 2 brackets off the tractor frame and add a raise/loader cylinder. Use the loader controls to do all the functions. You don't need pitch control if you set it up right, you need raise/lower and you very much need angle left & right.
Also, connecting and reconnecting couplers may not be practical if one gets pressurized. You will have to bleed it off to connect it.
/ need new snowplow #11
A seven footer on that tractor "may"be a bit too much.Depends how
much you get at a time.I had a six ft.on a L3130 sub-frame mounted
and that was all it wanted in deep snow.I had R1's rear loaded.
/ need new snowplow #12
Converting a front plow is by far the cheapest route. And if you already have front hydraulics and a ssaa....you don't have much work to do to adapt one.
/ need new snowplow
i was thinking it may be too much also... of course you get ALOT more snow than we do... i have been to Harrisville and Lowville several times.
