Snow Blade need new snowplow
/ need new snowplow #1
gravelman
Platinum Member
NH
Kubota 2650
gravelman here..i have a Kubota 2650 looking for a quick attach hydraulic angle snowplow...i believe it could handle up to 7 footer.... any brands suggested?? i like full trip too
/ need new snowplow #2
Your Kubota dealer should be able to help $$$$'s try Fisher & Boss & Curtis dealers.
/ need new snowplow
ok, good leads...thanks much
/ need new snowplow
i do not have a welder but know someone that does... i do have third valve plumbed to the front... thanks
/ need new snowplow #6
Perfect, plows have become stupid expensive and I and a few others here have some P.U. plow build threads if your interested in that route. I have the measurements/angles to build the ssqa.
As there's snow on the ground now, you may not have the time. I bought a "Snow Wolf" brand plow and it's been very tough. The 10,000 pound skid loader it's used on has no mercy on it and after 10-12 years, it's doing just fine. Skid Steer Plows, Skid Steer Snow Tires, Snow Pushers | SnowWolf Plows They have a dealer locator and iirc, Milton Cat is one.
/ need new snowplow #9
Purchased mine from Michigan Iron & equipment Morrice MI..Very stout set up..
/ need new snowplow #10
Or just pull the loader off, drop 2 brackets off the tractor frame and add a raise/loader cylinder. Use the loader controls to do all the functions. You don't need pitch control if you set it up right, you need raise/lower and you very much need angle left & right.
Also, connecting and reconnecting couplers may not be practical if one gets pressurized. You will have to bleed it off to connect it.
/ need new snowplow #11
A seven footer on that tractor "may"be a bit too much.Depends how
much you get at a time.I had a six ft.on a L3130 sub-frame mounted
and that was all it wanted in deep snow.I had R1's rear loaded.
/ need new snowplow #12
Converting a front plow is by far the cheapest route. And if you already have front hydraulics and a ssaa....you don't have much work to do to adapt one.
/ need new snowplow
i was thinking it may be too much also... of course you get ALOT more snow than we do... i have been to Harrisville and Lowville several times.
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
Massey Ferguson 9250 (A61307)
Massey Ferguson...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2018 Ford F-350 (A55973)
2018 Ford F-350...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
