need napa # for CPS for 7.3psd
   / need napa # for CPS for 7.3psd #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I want to pick up a glovebox spare cps for my 7.3psd, and searched and found that the ford number for a 99 ( post mid 97+ ) should be F7TZ-12K073-B however napa online crossref can't cross it. ( -A suffix for pre 97.5.. something about connector material.. )
I've seen mention on a diesel web site that a napa CSS-512 is the correct one.
Then again.. I also see mention of a napa CSS 1103 and a DEMHTS101
anyone got the skinny?
soundguy
   / need napa # for CPS for 7.3psd #2
All qualified advise in this neck of the woods says to use the OEM CPS. We run 3 7.3 PSD's at work, all 125K plus miles and each have had only one CPS change using OEM parts. Not sure this is the place to squeeze nickles.
I was actually just grabbing a spare. Mine has the ford 'recall' black cps vs the old grey one. however, I've always heard that the one GUARANTEED thing to leave you on the side of the road in a 7.3psd is that 35$-ish sensor, and that good insurance was to carry a spare in the glove box.
I've seen prices vary from 19$ to 65$ between aftermarket, international, ford, etc.
for a part that's not terribly expensive like that, and WILL leave you stranded ( never had it happen to me ).. I don't mind spending a few bucks for a spare.
I'll double check that ford part number but think I have it correct. suposedly the pre mid 97 ones had different contact material and could cause corrosion if used.. but otherwise are the same cps.. so i'm pretty sure the -B is the one i need on my 99.
thanks
soundguy
   / need napa # for CPS for 7.3psd #4
I get them from the International/Navistar dealer
i hear they have the blue flavored ones.
soundguy
already got it in the tool box.
soundguy
   / need napa # for CPS for 7.3psd #8
Same here, and don't forget the 10mm wrench.
Good call on the 10mm wrench, I kept an extra CPS and 10mm (6pt I think) wrench in my glovebox when I drove a 7.3.
   / need napa # for CPS for 7.3psd #9
I'm not at all against having a spare, just wanted to pass along the idea of an OEM part. The Navistar idea is a very good one, I'll bet there is a price difference.
yep.. the int. one was the most. I ended up hitting up my local ford dealer and grabbed a glovebox spare. in fact, saved myself some time and picked up a 1$ chinese 10mm wrench, and masking taped it to the box and tossed it into the glove box.. I told the guy at the store it was my roadside emergency PSD repair kit.. :) he kinda chuckled a bit.
thanks
soundguy
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2022 Caterpillar 310 Midi Excavator (A51691)
2022 Caterpillar...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
