Need Mechanic
   / Need Mechanic #31
Crap!!! Thats why I figured it may have taken so long but it did cross my mind that no damage to the head was found or mentioned.New the water/rust in that Cyl. didn't look good any shouldn't have been there But dang not from that.
Check into it were the crack is may be a easy fix. but the way I look at things like that is expect the worst and hope for the best.
Carey
   / Need Mechanic #32
Ray it's a sleeved engine. A pair of cylinder sleeve/piston sets is normal overhaul procedure.
Is it simply a sleeve that is cracked, or the block itself?
   / Need Mechanic
The one leak is coming from the rear of the head . The second leak is where the radiator hose connects to the block about 2 inchs behind fitting and appears to be about 1 inch long and coolant is leaking from crack. I don't know why it stopped unless its coolant leaking into fuel. When I turn it over get white smoke out of exhaust but will not fire.
Maybe someone local would like to buy as project. Everything works and has new skid steer turf tires on rear and loader has to be worth somthing.
   / Need Mechanic #34
"The one leak is coming from the rear of the head . "
Why.
A 1 inch crack is not necessarily a death blow. There are lots of block sealers on the market, and lots of vehicles running with them. I would definitely do some troubleshooting, find out why it won't run, why it's leaking at the head, does it need a sleeve, etc.
   / Need Mechanic
don't know will look further into leak near head will try to look this evening and update. Just really frustrated with this thing
   / Need Mechanic #36
Well Duh!!! I didn't look Ray that your in Fla. I would get with Norm he'd be the man to stay in touch with for your area. As knowlegable and honest as they get :thumbsup: I know he will point you in the right direction which ever way you decide to go.
Carey
   / Need Mechanic #37
There is a member here ( soundguy) that's in central fl . He restores vintage tractors . He may have run across this type of problem & may be able to offer you some assistance
   / Need Mechanic
I think I'm ready to give up and sell it as is. I want to move up to a bigger tractor anyway have a lot of work to do on 20 acre lot that needs clearing. How much do you guys think a ym2k with loader is worth. It has turf tires (skid steer) on rear. I figure the loader alone has to be worth it.
   / Need Mechanic #39
Looking in my Yanmar operators manual --
Engine smokes white: Wrong fuel, low temperature, air in fuel (lean), low compression, bad head gasket.
   / Need Mechanic #40
Put a price on it. I'll might come and get it. What part of central Fla are you?
Tractorman, Lincoln, Al
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2011 FREIGHTLINER CASCADIA (A50854)
2011 FREIGHTLINER...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2013 MACK GU713 (A50854)
2013 MACK GU713...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A51039)
2015 Ottawa Yard...
