Need measurement on BH92 backhoe attachment
   / Need measurement on BH92 backhoe attachment #1
Herkypilot
Platinum Member
Meadows of Dan, VA
Kubota M7060 HDC12, KX040 & L3540 HST
Hi all,
I'm working on converting my 3pt hitch backhoe to a subframe mounted hoe. I have an L3540 and found a subframe kit on ebay that fits this tractor. The subframe I have is made for a BH77 so I am unsure whether it is compatible with the BH92. I don't want to make a custom backhoe attachment to hook up to this subframe so my shortcut is to look at purchasing the Kubota brackets used on the BH92 backhoe side when hooking up to a "cab" tractor. These brackets are $209 each and I want to be sure they fit the subframe I have.
Here's a picture of the subframe I have. What I'm asking for is the distance from the bottom pin to the top pin on a BH92 to see if the Kubota extension brackets will work. I also need the "Pin" size for the top pins. The ones I have that came with the subframe are 1 1/4" in diameter.
Here's the extension bracket mounted on a Kubota BH92 on a cab tractor. I believe this belongs to Waxman.
Tractor side mounted subframe (not mine) and is marked with a yellow line for the measurement I'm looking for. Mine is 12 1/2" measured from bottom of the hole to bottom of the channel.
Thanks,
HP
   / Need measurement on BH92 backhoe attachment #2
If I remember I can measure for you tonight bud.
Thanks - I appreciate it.
HP
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
FORD F SERIES DUMP TRUCK (A57192)
FORD F SERIES DUMP...
Wooden Dining Table (A55853)
Wooden Dining...
2006 JOHN DEERE 650J XLT CRAWLER DOZER (A52707)
2006 JOHN DEERE...
2009 Nissan Maxima Sedan (A55853)
2009 Nissan Maxima...
OMNICUBE WALK IN FREEZER (A57192)
OMNICUBE WALK IN...
