need measurement off a 318
/ need measurement off a 318 #1
bruce1963
jd 318
Hope someone can help.I have a 1988 318 thats been repowered with briggs vanguard and it flips the pto belt.I believe the motor is to far back,can anyone give me a measurement from center of pto pulley to the vertical part of the frame where the motor bolts.I am talking the part that bends up about 2 inches in front of motor.Thanks.
/ need measurement off a 318 #2
the measurement is not important, what really matters is the belt alignment!. both pulleys need to align with each other, you should be able to measure that with a square, if not, then take measuring points to something original, to each pulley, make sure you have the same distance to that on each pulley.. if you could post a side picture of the engine pulley/PTO pulley, I should be able to tell you what happened..
/ need measurement off a 318 #3
I have 316/318 parts available near Saratoga Springs, NY. Parted out 4 tractors, lots of odd ball stuff. Best to call or text 744-3278 in 518 area.
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
Stout Brush Grapple XHD84-6 (A66285)
Stout Brush...
2012 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2012 VOLVO VNL 6X4...
