Need L3901 alternatives
   / Need L3901 alternatives #1
JonathanP
Kubota L2501
What would be a good alternative to a Kubota L3901, but from another company? Ty
   / Need L3901 alternatives #2
Deere 3039?
Not too familiar with newer Deere models but seems to compare in wt/hp/pto hp etc?
   / Need L3901 alternatives #3
Kioti CK4010 or DK4510 are good choices.
From late spring, last year:
   / Need L3901 alternatives #4
Kubota L3901 Dimensions
Kubota L3901 Weight
4WD Gear :2767 lbs
1255 kg
4WD Hydro :2778 lbs
1260 kg
Dimensions
Wheelbase:63.3 inches
160 cm
Width:55.1 inches
139 cm
Height (ROPS):91.7 inches
232 cm
2WD Ground clearance:13.6 inches
34 cm
4WD Ground clearance:13.4 inches
34 cm
Front tread:41.3 inches
104 cm (2WD)
Front tread:43.1 inches
109 cm (4WD)
Rear tread:43.8/47.1/50.8 inches
111/119/129 cm
Engine Detail
Kubota
diesel
3-cylinder
liquid-cooled
Displacement:111.4 ci
1.8 L
Bore/Stroke:3.43x4.03 inches
87 x 102 mm
Emissions:Tier IV
Power (gross):37.5 hp
28.0 kW
Fuel system:common rail direct injection
Rated RPM:2700
Starter:electric
Starter volts:12
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other single specification.
Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
   / Need L3901 alternatives #5
The 6.3 gpm on the Kubota seemed awful low so I checked. That is just for the main pump, there's another 3.8 for PS, so 10.1.
A Deere 3039R would be fairly comparable to an L3901 but the Deere has a little stronger loader and is a couple hundred pounds heavier. Plus it's fitted out as a deluxe tractor with electronic hydro, etc.
   / Need L3901 alternatives #6
Branson, LS and Kioti all make at least one model that competes. I found the L01 series to be pretty bare bones in terms of features. For example one feature I wanted was independent PTO so I would not have to get on the tractor to turn the PTO on and off like I did on my previous tractor. That's a pain when operating a PTO chipper or forestry winch.
Adding the regular and steering GPMs together is pretty much meaningless as they are never used together. It makes a bigger number though, that's why manufacturers do it. Most CUTS don't have enough hydraulic flow to do work like running a hydraulic mower or brush cutter or snow blower. That's skid steer territory of 20gpm and up. All CUTS really need is enough to run a loader or backhoe.
   / Need L3901 alternatives #7
Kubota L3901 Weight
4WD Gear :2767 lbs
1255 kg
4WD Hydro :2778 lbs
1260 kg
Dimensions
160 cm
Width:55.1 inches
139 cm
232 cm
34 cm
34 cm
104 cm (2WD)
109 cm (4WD)
111/119/129 cm
Engine Detail
Kubota
diesel
3-cylinder
liquid-cooled
1.8 L
87 x 102 mm
Emissions:Tier IV
28.0 kW
Rated RPM:2700
Starter:electric
Starter volts:12
Have to agree, look at the weight first, then check for access to the dealerships as support is paramount especially with supply chain issues. They are not all the same and then I would dig into the quality and reliability as any tractor runs good the first 20 hrs, it's the next 2000 you need to worry about.
I don’t understand what CUTS are. Are you saying this model Kubota couldn’t run a brush cutter well?
   / Need L3901 alternatives #9
Compact Utility Tractors don't have the hydraulics to drive hydraulic implements well.
PTO driven cutters and other implements are fine.
Toyota 7FDKU40 7,350lb Forklift (A55973)
Toyota 7FDKU40...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2015 Freightliner M2 106 4x4 Altec DM47B TR 47ft Digger Derrick Truck (A55973)
2015 Freightliner...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
