Need input on snowplow
   / Need input on snowplow #41
It is a 85hp tractor.
The option of a grader would be ideal, but have you ever tried to get 15 property owners to agree, much less pay for something together?
Any suggestions on where to look to find a snow blade heavy enough to survive this kind of use over repeated seasons?
Here is another for you.
Machinability Snowplows
Thanks for all the input.
Any suggestions on what size blade to use? The bucket is 7' wide, I know the blade needs to be at least 8' to maintain tire clearance when it is angled. My concern is weather I should just go ahead and get a 10' blade to avoid sloughing and buying another blade.
E/S
   / Need input on snowplow #43
E/S
I would go with a 8' or 8.5', 9' at the very most.
10' would be to much, especially on the FEL, IMO
   / Need input on snowplow #44
I plow miles of big snow at 3300+ EL.
Kubota L5030, Curtis 7.5 power angle snowplow, Loftness 841S Blower on rear.
Tires/Wheels reversed to the widest possible position; makes for easier chain installs and removals and helps if you are on unlevel terrain.
Snow Chains (H on back, V bar on front) on R1 tires
Rim Guard in the rears.
Message - TractorByNet.com Photo Gallery
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
26120 (A56859)
26120 (A56859)
