Need Ideas: Rock Screen to Filter Topsoil.
   / Need Ideas: Rock Screen to Filter Topsoil. #11
Here is a really simple screen I made using heavy duty 1-1/2 inch chain link fence and a few 2x4s and 2x6s. I have used it to screen about 100 yrd of soil so far this summer. I have screened out lots of large rocks some weighing more than 50lbs without any damage to the chain link fencing. Sod is the biggest pain in the neck because it does not slide down the screen very well.
   / Need Ideas: Rock Screen to Filter Topsoil. #12
</font><font color="blue" class="small">( Here is a really simple screen I made using heavy duty 1-1/2 inch chain link fence and a few 2x4s and 2x6s. I have used it to screen about 100 yrd of soil so far this summer. I have screened out lots of large rocks some weighing more than 50lbs without any damage to the chain link fencing. Sod is the biggest pain in the neck because it does not slide down the screen very well. )</font>
How
long wide and high is it?
How much wider than your FEL bucket is it?
   / Need Ideas: Rock Screen to Filter Topsoil. #13
It is 7' wide by 10' long.
   / Need Ideas: Rock Screen to Filter Topsoil. #14
</font><font color="blue" class="small">( It is 7' wide by 10' long. )</font>
Thanks for the information!
Do you leave it set where it is in your picture or do you take it down and move it around from place to place?
Your tractor is quite a bit bigger than my BX 23 so I'm thinking of going with 8' long by 5' wide. Do you think this size would work with my smaller BX 23 ?
I'm trying to keep it as small and light as possible to accommodate ease of portability.
Thanks again you've been most helpful.
   / Need Ideas: Rock Screen to Filter Topsoil. #15
I leave this one where it is. I do have more chain link fence available and am thinking of building a smaller portable screen. I know it will be a while before I get around to doing it.
   / Need Ideas: Rock Screen to Filter Topsoil. #16
Nice simple design there luremaker, thanks for posting it.
   / Need Ideas: Rock Screen to Filter Topsoil. #17
I wouldn't use chain link fence. Too flexible.
I would use rabbit wire fencing.
It's like concrete reinforcement wire, but smaller squares.
You just need a box with this wire mesh on the bottom,
and a track for the box to move back and forth on,
and a crank shaft and rod to move it back and forth.
Should be real easy to make up something like this.
I was thinking of getting an old dryer drum and mounting it
like a concrete mixer. The drum is full of holes all around.
Just shovel river gravel/sand into it and let it spin.
The sand would drop out under it and every so often dump the gravel.
I'm on the Sequatchie river and got lots of river sand/gravel.
Last year's floods created a pile 10ft+ high last year,
but its on an island and I can't get to it.
I'd have to cross fast moving water about chest deep and about 15ft wide.
But there's still plenty of it on my side.
Pooh Bear
   / Need Ideas: Rock Screen to Filter Topsoil. #18
   / Need Ideas: Rock Screen to Filter Topsoil. #19
#11 rebar. 4” c channel. High security chain
Link fence ( small holes ) 64” wide I used my 5’ bucket with teeth to screen
   / Need Ideas: Rock Screen to Filter Topsoil. #20
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2011 Kenworth T700 T/A Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T700...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2019 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
