Need ideas for adapting boom pole to FEL/pallet forks
   / Need ideas for adapting boom pole to FEL/pallet forks #11
Different style of forks and boom pole used 3pt drawbars to clamp it up. Lift tested with old engine block.
Loaded tires & 700# rear blade, 70's era ford, real cast iron frame.
pin on forks, if using SSQA consider a way to lock it to the FEL
How high is your peak/ridge planned for?
When I did mine over the last couple of years, I made sure it wouldn't be beyond a height I could reach by ladder or scaffold. Ended up being around 13' with 8' walls as i remember. From there, I was able to hoist rafters into place using a rope and pulley setup (not quite a block and tackle). I'd set one end on the wall top, then go up the ladder or scaffold, pull the ridge end into place, tie it off, then fasten/secure.
Peak will be about 18', but I am looking at a monitor style plan, which means I can build the high roof using the second floor as a scaffold, and use a ladder there. Reality is, I could probably do it by hand, but it would be nice to lift the bigger boards with the boom pole and just set them in place before fastening.
   / Need ideas for adapting boom pole to FEL/pallet forks #13
Farther the load gets from pins the more net lift you lose.
Friend used a smaller bucket truck than mine to raise barn trusses. (Chevy C-30 vs F-450 SD)
Lift & set them upside down, then turn upright to install/brace. (the part you knew already)
   / Need ideas for adapting boom pole to FEL/pallet forks #15
Did exactly what you are planning this past summer. Raised a pole barn and set trusses on 12' walls. Bought a 20' square pole for $100 and attached a Harbor Freight electric hoist. Allowed us to easily lift the trusses and raise them up and down with precision to set them exactly where we needed them. Supported the pole with chains attached to the front end loader mount. Built a jig to attach to the trusses so we could pick them up across multiple places so we would not damage or overstress the trusses. Screwed the truss to the jig so there was no chance of dropping the truss accidentally.
   / Need ideas for adapting boom pole to FEL/pallet forks #16
For my version I used a 4" "H" beam 20' long with brackets welded on so it would slide over my forks and a chain to hold it from sliding off if I pointed it down. I set trusses on top of a 10' wall and 24' wide building so I had to reach over 12' to set them. Trusses are 24' wide by 5' tall. My loader is rated for 3000#, but with the 20' extension I was limited to just a few hundred. The 24' trusses weighed about 150#.
   / Need ideas for adapting boom pole to FEL/pallet forks #17
I did this when building my house. There are threads with pics elsewhere here on TBN.
I welded a QH to a QA plate so I could also use landscape rake.
I also made an extension for the boom pole, also added a 12v winch. Lifted a lot of stuff, beams and roofing panels. Watch your counter weight and do be careful, but very doable and productive. Sometimes wife would work the tractor when I placed the load.
   / Need ideas for adapting boom pole to FEL/pallet forks #18
I second this! For my pole I simply added a short length of chain and some metal hooks to pick up trusses. I just finished placing trusses on a 30 x 50 shop, 16 foot walls and 5x12 pitch. Easy-peasy. With this kind of extension you learn that the curl circuit is too fast, easier to tweak placement using 'angle of the dangle' and the loader circuit.
   / Need ideas for adapting boom pole to FEL/pallet forks #19
The straight boom fastened to the lower edge of a bucket or forks or SSQA adapter with a couple of stabilizing chains will do a good job.
I don't know about the others that posted pictures of the quick hitchs mounted to the SSQA plates, but when I did mine I did it quick and easy.
I just welded the quick hitch to the plate, with the geometry of my loader that was a mistake I should have spaced out the bottom of the quick hitch
three or four inches from the plate many times I can't get the curl back I'm looking for when using it.
   / Need ideas for adapting boom pole to FEL/pallet forks #20
more pics I saved
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
205196 (A52706)
205196 (A52706)
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
