Need ideas for a raised walkway
   / Need ideas for a raised walkway
How about just getting the pathway a bit more elevated in the first place? Some loads of dirt to raise it up out of the ditch it appears to be now. Then topping it with something like loose mulch would keep it from as easily turning into an ice sheet.
A heated concrete sidewalk sounds like an easy way to blow 50 grand here. Keep it simple to start, and see if it improves enough for ya.
Yes, we've thought about that, problem is mud in the spring thaw and early fall rains. If I shovel/plow the snow off the grass, once it starts to warm up the path turns to mud, then we kill all the grass. We also have 3 goofy dogs that tear ass up and down these paths so it gets a lot of wear and tear.
   / Need ideas for a raised walkway #13
Build the path couple inches or so above ground level hard pack material bucket wide,store some grit material when it gets icy.
   / Need ideas for a raised walkway #14
Well thats exactly my point, get the pathway elevated at least several inches above the yard level, with a gentle crown on it - it will shed water and not turn to mud. Mulch can be refreshed every year with a new bag or three, to avoid turning to mud also.
Better than a raised walkway would be a railing all the way out there . Less work to clean.
Now that's an interesting idea. I have to talk to the control tower about that.
   / Need ideas for a raised walkway #16
I keep several pairs of studded slip ons in the garage. They are cheap and easy to put on and take off. They are just a fact of life up north.
   / Need ideas for a raised walkway #17
I once lived in a house that had wooden walkways. Besides being slippery when wet, they make excellent hiding places for rabbits and other such critters. My neighbor's dog had a great time digging and destroying the walkways to get the rabbits. The guilty party would have gotten away with it if only she hadn't left her collar hooked on one of the broken deck boards. No word on the condition of the rabbit.
Raise the walkway with dirt and lay down some pea gravel on the surface?
   / Need ideas for a raised walkway #18
Following as we have similar issues that I would like to resolve.
We have 3 dogs that spend most of their time chasing rabbits and chipmunks. Good point
   / Need ideas for a raised walkway #20
Walkway of gravel. Well mounded and graded. Get a set of Muck boots. Clamp on a set of removable spikes. Use the boots when you walk the trail in the winter.
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
1999 FREIGHTLINER FL80 (A50854)
1999 FREIGHTLINER...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
197637 (A50459)
197637 (A50459)
