Need Ideas for a drag
/ Need Ideas for a drag #1
Redneck_Randy
Platinum Member
Oklahoma
2005 New Holland TC35A
Geting ready to till areas of my lawn and then seed. I first need to make a drag to level the dirt before seeding. I've read about using a piece of chian link fence and a couple pieces of pipe. Would appreciate any photo's anyone would care to post to give me ideas.
Thanks
/ Need Ideas for a drag #2
Iv;e used a piece of 4" chanel iron that worked pretty good. kje
/ Need Ideas for a drag #3
I use an old harrow section
John
/ Need Ideas for a drag #5
I have about 1/3 of a side of an old cattle head gate I use for really rough stuff, have to pull it with the tractor it's so heavy. I've got two pieces of 2" pipe with cement in each end chained to each other about 4' apart I use behind the 4-wheeler for leveling places where I don't need to drag out a lot of grass, mainly places I keep disced up all the time.
/ Need Ideas for a drag #6
I always thought you were supposed to seed before you dragged? I guess you could drag smooth, seed and then drag again for seed coverage. Please let me know what the correct method is as I'm about to do this.
There was a recent post about this. Old bed springs were another type of drag commonly used.
http://www.tractorbynet.com/forums/attachments/86412-making-drag.html
/ Need Ideas for a drag #7
I use the tounge from a mobil home that the owner actually paid me to remove.
/ Need Ideas for a drag #8
My grandfather uses an old bed spring around his garden and yard. He ties cement blocks on top of it for extra weight when he needs it. Works well.
/ Need Ideas for a drag #9
If you need to level the land prior to seeding a heavy object druig at an angle wiill be what you are looking for. It should be solid and as long as the tractor can pull. You should drag from diferent directions, till and drag again for a level lawn area. Might even take more times depending on how fussy you are. The draging will compact the soil.
Till again before seeding to loosen up the soil and use a harrow of some type to cover the seeds.
I made a smal harrow. [ pic. attached ] As you cansee it also has other uses.
/ Need Ideas for a drag #10
Chain a few logs together about 8 feet long. keep about a foot or 2 of chain between each log. You can change the angle by were you grab the lead chain
/ Need Ideas for a drag #11
You DON'T want "seed coverage". Bad idea. Grass seed wants sunlight to germinate. It needs SOIL CONTACT, but not to be buried. Wheat, barley, ect, (cereal grains) can be buried slightly. Grass just wants to be pressed into the already FIRMED surface. (Grass doesn't do as well in deeply loosened soils) A cultipacker after seeding is the best alternative.
Now to the original question....... A good "drag". SouNdguy put me on to a good idea. Get yourself a "stock panel". (from TSC among other places) Take a bolt cutter to random wires and then bend them down to form spikes. Relatively cheap, works good, and easy to find.
/ Need Ideas for a drag #12
Thanks
This may be overkill for a lawn, but I have about 7 acres that need to be disked and smoothed.
Got a bunch of free old tires from a guy North of my place. Plan to make a drag out of them.
Thanks for all the idea everyone. :D
I ended up making drag out of a chain link gate (4'x4') that I attacked two pieces a of pipe on the top then attaching a small piece of plywood to. I blocked in with 1x2 to hold in place 2 cinder blocks for weight. I was amazed how well it wokred. I pulled it around with my ZTR Dixon because the tractor would have packed the soil down to hard for grass seed. After dragging it level and making sure I didn't change any of my tapers for water drainage I then seeded and drove the ZTR over it one last time to compact the seed into the top of the soil. I then finished off with watering. I'm only doing about 1/2 acres in the front of the home this year. I've never planted seed with much luck in the past but this time I did my research on soil prep and hoping for much better results. I even had my soil tested. Soil was good just needed to be tilled and loosened up and lightly packed in place. I was told after tilling and rolling/compacting you should not have more then 3/8 of a compaction when you walk on it. I'm right at that and maybe a tad less. I recieved most of my info from the local sod farm here. He even took me out to freshly prepped filed ready for seed to look it over.
Again, thanks for all the info everyone!!! :D
/ Need Ideas for a drag #14
Oh great! Now we'll have a 20-page debate on "radials vs. bias ply to level your lawn" post................. ;)
Actually, that's a GREAT way to level ground and beat the life out of clods of dirt. I watched a contractor that builds "sports fields" do a seed bed for a soccer field with a tire drag a while back. It worked to perfection.
