Need hydro adapters
   / Need hydro adapters #1
Taxidermist
Fowlerville Michigan
Branson 3510
I am adding rear remotes to a Branson 3510 I was told i need adapters to go from MM to jic/pipe
Here is what i am looking for 20mm x 1.5 pitch ORB adapter in each hole that comes out to a JIC or pipe
I cant find any. I sent a e mail to davestractor but have not heard from him yet.
Thank you,
Rob
   / Need hydro adapters #2
I am finding listings forM18 x 1.5 and M22 x 1.5, but M20 x 1.5. Are you sure of the size?
Nope! I was told that was the size by a member here davestractor.
"Just about directly under the seat on the right side of the rear axle housing up high, but still on the side (not the top) is a pair of banjo fittings right next to each other that are actually connected. Remove those and install a 20mm x 1.5 pitch ORB adapter in each hole that comes out to a JIC or pipe and you are good to go. The front port is pressure, the rear continues the flow. We've done dozens, but by the time you get a nice two or three spool valve and a top and tilt cylinder, then spend several hundred on hoses, fittings, disconnects, etc...it still gets expensive."
   / Need hydro adapters #4
Discount Hydraulic Hose has the fittings you need.
Male M20 x 1.5 to Male JIC.
Metric side includes washer and O-Ring
Item 9065S-06-S12-20 has #6 (3/8") JIC Male
Item 9065S-08-S12-20 has #8 (1/2") JIC Male
Item 9065S-10-S12-20 Has #10 (5/8") JIC Male
   / Need hydro adapters #5
Dave was at the Tulare World Ag Expo this past week, I'm sure that he will get back with you as soon as he can.
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2002 Enclosed Cargo Trailer (A52377)
2002 Enclosed...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
Adams 5T High Clearance Fertilizer Spreader (A53473)
Adams 5T High...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
SHOP FAN (A53843)
SHOP FAN (A53843)
