Need hydro adapters
/ Need hydro adapters #1
Taxidermist
Fowlerville Michigan
Branson 3510
I am adding rear remotes to a Branson 3510 I was told i need adapters to go from MM to jic/pipe
Here is what i am looking for 20mm x 1.5 pitch ORB adapter in each hole that comes out to a JIC or pipe
I cant find any. I sent a e mail to davestractor but have not heard from him yet.
Thank you,
Rob
/ Need hydro adapters #2
I am finding listings forM18 x 1.5 and M22 x 1.5, but M20 x 1.5. Are you sure of the size?
Nope! I was told that was the size by a member here davestractor.
"Just about directly under the seat on the right side of the rear axle housing up high, but still on the side (not the top) is a pair of banjo fittings right next to each other that are actually connected. Remove those and install a 20mm x 1.5 pitch ORB adapter in each hole that comes out to a JIC or pipe and you are good to go. The front port is pressure, the rear continues the flow. We've done dozens, but by the time you get a nice two or three spool valve and a top and tilt cylinder, then spend several hundred on hoses, fittings, disconnects, etc...it still gets expensive."
/ Need hydro adapters #4
Discount Hydraulic Hose has the fittings you need.
Male M20 x 1.5 to Male JIC.
Metric side includes washer and O-Ring
Item 9065S-06-S12-20 has #6 (3/8") JIC Male
Item 9065S-08-S12-20 has #8 (1/2") JIC Male
Item 9065S-10-S12-20 Has #10 (5/8") JIC Male
/ Need hydro adapters #5
Dave was at the Tulare World Ag Expo this past week, I'm sure that he will get back with you as soon as he can.
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
New/Unused Receiver Hitch (A61166)
New/Unused...
2024 Schulte 5026 Batwing Rotary Cutter (A63118)
2024 Schulte 5026...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
24220 (A56859)
24220 (A56859)
