Need hose lengths for Country MFG 2ton trailer
   / Need hose lengths for Country MFG 2ton trailer
Just placed my order with Surpluss center - 8' & 10' hoses - 1/2" double braid, 2 90 degree swivel fittings and a 3 1/2" x 24 cylinder chief tie rod cylinder. Just over $200 with the $30 shipping:eek:
My tractor only has 1,850 psi hydraulic system. with a 3" cylinder, I'd get ~13,000# push, but with the geometry, the cylinder would have to be at 18 degrees to get 4,000# of upward push. A 3.5" cylinder gets me ~18,000# push and 4,000# at 13 degrees. Without having the trailer in front of me to measure the angle, I went a little conservative.
A 4" cylinder would give me ~23,000# push and 4,000# at 10 degrees. It is also amost twice as slow as a 3" cylinder for cycle time.
   / Need hose lengths for Country MFG 2ton trailer #12
Haz,
Sounds like you should be good to go. The extra 1/2" in cylinder diameter oughta give you a little fudge factor .... you'll get a sense pretty quickly of how much the trailer will easily handle.
In my case I figured I was loading a little heavy when I would go to dump and the bed would bow pretty good front to back - probably better than an inch front to back. Only happened when I would heap the trailer with wet material.
Dunno what the at rest angle is ..... there is some .... just not alot.
   / Need hose lengths for Country MFG 2ton trailer #13
The angle at rest is around 10 degrees +/-, definately less than 15 degrees as best as I can measure. That is on the dump wagon.
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2007 KUBOTA M5040F TRACTOR (A51243)
2007 KUBOTA M5040F...
