Need hose lengths for Country MFG 2ton trailer
   / Need hose lengths for Country MFG 2ton trailer
Just placed my order with Surpluss center - 8' & 10' hoses - 1/2" double braid, 2 90 degree swivel fittings and a 3 1/2" x 24 cylinder chief tie rod cylinder. Just over $200 with the $30 shipping:eek:
My tractor only has 1,850 psi hydraulic system. with a 3" cylinder, I'd get ~13,000# push, but with the geometry, the cylinder would have to be at 18 degrees to get 4,000# of upward push. A 3.5" cylinder gets me ~18,000# push and 4,000# at 13 degrees. Without having the trailer in front of me to measure the angle, I went a little conservative.
A 4" cylinder would give me ~23,000# push and 4,000# at 10 degrees. It is also amost twice as slow as a 3" cylinder for cycle time.
   / Need hose lengths for Country MFG 2ton trailer #12
Haz,
Sounds like you should be good to go. The extra 1/2" in cylinder diameter oughta give you a little fudge factor .... you'll get a sense pretty quickly of how much the trailer will easily handle.
In my case I figured I was loading a little heavy when I would go to dump and the bed would bow pretty good front to back - probably better than an inch front to back. Only happened when I would heap the trailer with wet material.
Dunno what the at rest angle is ..... there is some .... just not alot.
   / Need hose lengths for Country MFG 2ton trailer #13
The angle at rest is around 10 degrees +/-, definately less than 15 degrees as best as I can measure. That is on the dump wagon.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2012 LINDE H80D FORKLIFT (A50854)
2012 LINDE H80D...
Caterpillar Front Glass (A50854)
Caterpillar Front...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
Husky GHM105890 Cement Mixer (A49461)
Husky GHM105890...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
