Need high lift blades for 48" "replacement" deck
   / Need high lift blades for 48" "replacement" deck #1
DanMc77
JD 4600, JD 2210, JD 332
I hit a big rock while mowing with my 332. It hit hard enough to shear off the blade bolt and bent the blade. I may also have a bent spindle, I'll find that out once I flip over the deck and get a look. With 20+ years on these blades, it's time for a new set anyway. I want to get high-lift blades this time.
Anybody have any recommendations? Where do I find good heavy high-lift blades for the 48" replacement deck?
   / Need high lift blades for 48" "replacement" deck #2
Oregon has blades, John Deere has blades too.
   / Need high lift blades for 48" "replacement" deck #3
Since it's a replacement deck are the specs on the blades the same as oem that came on it?
If not you'll need to measure the length of current blades and bolt hole size to be sure what to get.
Beings it's a 48" cut should be a common size.
   / Need high lift blades for 48" "replacement" deck #4
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2006 VOLVO VNL DAY CAB (A52577)
2006 VOLVO VNL DAY...
Fuel Tank (A51573)
Fuel Tank (A51573)
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
