Need high lift blades for 48" "replacement" deck
   / Need high lift blades for 48" "replacement" deck #1
DanMc77
JD 4600, JD 2210, JD 332
I hit a big rock while mowing with my 332. It hit hard enough to shear off the blade bolt and bent the blade. I may also have a bent spindle, I'll find that out once I flip over the deck and get a look. With 20+ years on these blades, it's time for a new set anyway. I want to get high-lift blades this time.
Anybody have any recommendations? Where do I find good heavy high-lift blades for the 48" replacement deck?
   / Need high lift blades for 48" "replacement" deck #2
Oregon has blades, John Deere has blades too.
   / Need high lift blades for 48" "replacement" deck #3
Since it's a replacement deck are the specs on the blades the same as oem that came on it?
If not you'll need to measure the length of current blades and bolt hole size to be sure what to get.
Beings it's a 48" cut should be a common size.
   / Need high lift blades for 48" "replacement" deck #4
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2023 JOHN DEERE 3033R LOT NUMBER 90 (A53084)
2023 JOHN DEERE...
Toro Mower (A50324)
Toro Mower (A50324)
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
