Need help!
/ Need help! #1
jasonzee
farmtrac555
Last wk. I changed my started
And fuel filters and I bleed to the injectors
And know it starts. My question is what's
The wheel next to the filters do?
/ Need help! #2
The wheel off the injector pump is the hand primer. It's a little plunger that is typically screwed down. You loosen the bleed screw on your filter housing. Lefty loosen the primer wheel and then move the plunger up and down until you've bled the air out. Tighten your bleed screw.
The other circled red thing on the right in your picture is the engine oil filler cap if I remember right.
/ Need help!
Thanks
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
PALLET OF FILTERS & MISC (A64278)
PALLET OF FILTERS...
UNUSED JCT-72" HYD TILLER (A65055)
UNUSED JCT-72" HYD...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
