NEED HELP
/ NEED HELP #1
robertdeatley
BATAVIA OHIO
KIOTI DK45S
THE OTHER DAY I TRIED TO START MY KIOTI DK45S CRANKED OVER ABOUT FOUR OR FIVE TIMES THEN A PUFF OF SMOKE CAME OUT FROM UNDER THE HOOD WHEN I CHECKED TO SEE WHAT HAD HAPPENED FOUND THE NEGATIVE BATTERY CABLE HAD SHORTED OUT REPLACED CABLE BUT NOW NO START IT DOSE CRANK OVER BUT NOT GETTING FUEL ENGINE FUEL IS CLICKING AND SECOND LIGHTER CLICKSHORTLY AFTER ALL LIGHTS ARE WORKING GLOW PLUG EXCERTA
/ NEED HELP #2
Must be a blown fuse some place ( ? )try placing your hand on the fuel relay to feel if it clicks when you turn the key on as well as try the same thing on the fuel solenoid.
/ NEED HELP
They do appear to be working they click when the ignition is turned on and all fuses are good
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
(2) Acetylene Torches (A65579)
(2) Acetylene...
New Quick Hitch (A65579)
New Quick Hitch...
2003 Kenworth T800 Log Truck (A62679)
2003 Kenworth T800...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
