Need Help
/ Need Help #1
Fisherman305
Monroe County WestVirginia
I have finally found a John Deere 350 sickle bar mower 7ft it is in outstanding shape. Asking price is $1200. Help needed. Is this sickle bar mower too large for my B7800 4wd 30HP kubota? I am unable to locate any information on the mower from John Deere such as wait and recommended HP. All posting will be appreciated. Need to know what you think soon for it will not last. [/list]
/ Need Help #2
Don't know if this will help you, but I have a Haban Sickle Bar mower on my Bolens Garden Tractor that is 54" and the tractor weighs less than 1200 pounds and is a 20 HP Gas job. I think that if you can modify it to fit, it will work... the sickle bar mowers aren't that heavy..... if not, if the price is good, then you can always resell it. I have learned that if you hesitate too long, you can repent in liesure......
/ Need Help #3
Ah, finally I have something I know about:
Many Many years ago, I had a JD model M that came with a 7' sickle mower. It was all the tractor could do to run it, especially in grass.
What I did was cut 12" off the end of the sickle bar, and cut the sickle to match. Easy to do with a torch. Remounted the "end pieces". Had to drill a couple of holes as I recall, but that was a nothing.
Ended up with a 6' mower that worked great! If you get a good deal on the 7', try it; worst case you can make a 6'!
Enjoy,
Ron
/ Need Help #4
You do not say if it is a 3 pt or a pull type mower. Two years ago I purchased a old JD11 9 foot mower, it is a pull type. Paid $500 for it. Needed a few guards replaced, a lot of the others are quite worn, should also have a new cutting blade.
I have a NH1630, which is about 24HP at the pto and weighs about 2000 pounds. The tractor handles the mower just fine.
/ Need Help #6
Fisherman, you were asking for info on KD101 at Agri-Supply a week ago or two. What happened? Have you got any info on it? If I'm not wrong, this KD101 a 6 ft mower and it has a hydraulic lift (optional) and I guess it looks like this (see picture attached.) This 6 ft mower I own works with 30 HP without any problem. So, I am almost sure that you will have no problem with that JD 7' mower. If you still face any problem, just remove some knive to reduce it to 6 ft. So, I say go for it 7 ft mower - you may buy a bigger tractor in the future, who knows.
/ Need Help #7
By the way, I just wanted to show you another sickle mower. (see attachment) - A reproduction. New!!. Really. lol
/ Need Help #8
I think it is to big!!! those were built for the older 30,40 to fifty plus horsepower tractors that weighed a lot more then your tractor.
/ Need Help #9
Nomad
The last time I used a mower like that the seat was different and it was pull by 2 horses(4 footed type) or one might say 2HP.
/ Need Help #10
</font><font color="blue" class="small">( Nomad
The last time I used a mower like that the seat was different and it was pull by 2 horses(4 footed type) or one might say 2HP. )</font>
Deerlope, the backs of farmers in this era are more, how you say?, "girly"? than the old days - hence, softer seat;-)
By the way, an interesting thing you mentioned. If this old horse driven sickle bar mower can be pulled by 2 Horses (by 2 HP as you said), why 30 HP is required to pull a tractor driven sickle bar mower with almost same sickle bar length? Here is a contradiction or not? One requires 2 HP and the similar one requires 30 HP!!
/ Need Help #11
I would think that if the mower weight falls within the 3 point lift specs it will handle the mower. The tractor has more than enough horsepower to operate the sickle.
/ Need Help #12
i would say that the weight of the sickle bar shouldn't be a concern. we have a 5' mid mount sickle on our 45 farmall A and you can lift the tip of the bar with one hand.
as for the size, you might find it a tad big in really heavy grass, if so, you can shorten it, or slow the tractor down.
/ Need Help #13
I really doubt that that is a newly produced mower. It looked orignail, with the pole being cut off so it will work better being tractor pulled. someone has made a halfhearted attemp to make a double whipple tree that would be used if 2 horses were hitched to it.
/ Need Help #14
No, it is really new although it is a little rusty because it has been kept outdoor for months. It looks like original because it is a copy with some changes from original mower. This was made for two reasons; 1. hobby 2. for the fields like mountain or hills where tractor can't access.
/ Need Help #16
</font><font color="blue" class="small">( Is that mower pulled with horses? )</font>
Yes, it's pulled with the horses. But a power of 30 horses (tractor) too can pull;-)
Ps: This small craft too is pulled by the horse;-) (see attachment)- I also do somethings different in my spare time. just for fun.
/ Need Help #17
If you made, it is a beautiful piece of workmanship, and if you did not whom ever did my hat is off to them.
/ Need Help #19
Actually, I am making such handcraft carts in a small workshop (you call "blacksmith"?) of a friend here and we make them together. He has wood tools in his workshop and I sometimes work there. just for fun. Thanks for the good words. Hand work is a joy.
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Woods BW180HD Batwing Mower (A66285)
Woods BW180HD...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
3pt Bale Spear (A64127)
3pt Bale Spear...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
