need help
/ need help #1
Kodiak45
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
I Was plowing withh my long 2460 and it started reving up sporadically every few minutes for a few seconds and then she cut off and won't start back up.. where do i start with diagnosis?
/ need help #2
Is it possible that your 2460 is out of fuel? Revving up sporadically is a sign of a diesel sucking air.
If it is a diesel.:D
/ need help
i suppose that is possible, but i just put a few gallons in last weekend and i swore to myself i would never let that happen again.the gauge doesnt work, so I'll see if that is it. i sure hope so. i dread the task of priming the fuel system, but i hope that's it. if i pull an injector and turn it over and fuel comes out, then that would eliminate that possibility right?
/ need help #4
I am by far no mechanic but just went through problems with the fuel system last fall. Left tractor setting and when I went to start it I checked fuel and it was low but should have made it in. Had to go down a hill which allowed the fuel to run to one side of the tank and not get any to the fuel line.
Ended up having to replace the fuel pump, filters while I was at it. Then for good measure a ring broke in the engine. Now having hydraulic problems. The output pipe from the pump was taken loose. An o-ring goes in and have replaced with one but not sure if it is the right size. Supposed to be. I ordered the whole o-ring kit but none of them were marked. Top of hydraulic pump leaks bad. Where the metal pipe screws down their is an indention that looks like it is for an o-ring. Only other choice is to lay one on top of the pump.
If you ever have to remove the pressure line from the pump be careful putting the screws back it. They are soft and will shear in a heartbeat.
Hope this helps. I did have to replace an injection pump a few years back. Threw parts out the side. Best I remembered it reved up then shut down. If you have to purchase any major parts check fleabay. Saved a bunch on an alternator I had to buy.
/ need help
it did have air in the fuel line, so i primed it and its running now. but there was over half tank of fuel, so how did air get in the lines. i wasnt on steep grade or anything. any ideas?
/ need help #6
any weepy lines at the pump or filter elements or heads?
/ need help
no and the filters were replaced last year. the only thing it leaks bad is hydro fluid. i pressure washed the engine a few weeks ago...?
/ need help
i probably ran it for 4+ hours after i cleaned it
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
36in Forks (A64553)
36in Forks (A64553)
2017 Nissan Sentra Sedan (A64557)
2017 Nissan Sentra...
2011 International DuraStar 4300 Mobile Food Prep Truck (A64194)
2011 International...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
