Need Help!!
   / Need Help!! #1
darcypid
Vegreville,Alberta
Hi to all!
I am a horse owner on a 25 acre acreage.I need a tractor for moving snow,and just big enough that I could move around round bale.I would need 4x4 and a cab,In the 20000-30000 price range.What do you all recomend?
   / Need Help!! #2
Hi to all!
Depending on your local tractor market and whether you want new or used, I would think a 50 HP. tractor would be just fine and if you want to move snow you would want a front end loader with a quick attach so you could use a blower, plow, bucket or hay spear or a cheaper way would be to use the 3 point hitch for a hay spear, blower or back blade. So much of this is your own preference but with your budget you should have no problem.
   / Need Help!! #3
If you look at used ones, you may be OK, but to get what you named; i.e., cab, 4WD, and big enough to lift round bales, it might be tough to find something in your price range. If you want to use something like a Hay King 3-point hay spear instead of lifting round bales with a front end loader, you might have a better chance of stayng within your budget.
   / Need Help!! #4
4wd and a cab puts you into an 80's+ machine if looking used.
I agree that a 45 or so hp machine will be where you want to look.. anything smaller is dicey with rounds.
soundguy
Tradewinds Power Unit (A50120)
Tradewinds Power...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
2020 KUBOTA RTV...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
