need help
/ need help #1
mapa
hi guys I read some of your posting and bet someone can help me
I'm looking at buying a tx1510 with a burned out clutch replacing the clutch shouldn't be to bad whats bugging me is the seller said it drives until it warms up the fluid , am I missing something ? I'm told this is gear driven
/ need help #2
Hi, let me take the honor to welcome you. (be aware you'll get hooked before you know)
I dont know your background so i might be underestimating your skills.
Going from your description I can already see the story....
Owner pushes the tx too far, overheats the engine and burns the clutch, now sells the tractor.
A TX is a conventional system, so gears all around. The fluid can be 2 things but in this case i dont see how it can be something else than the cooling liquid.
(other would be hydraulics)
A diesel engine cutting out when heating up is loss of compression in other words shot engine. No way to say if that would be a rebuild or scrap based on this info only.
Whole other question for you to decide if you would venture into a rebuild. (simpel one or extensive)
The burnt clutch is not that difficult as far as splitting the tractor and replacing the clutch is easy for a home-owner. (i mean to say: do you have the tools and do you have enough mechanical "baggage" to take a job like this)
I would be very careful with this tractor knowing these 2 problems. If you are sure you can make the repairs by yourself then maybe ask for a quote to have the work done by a service dealer and use it as a negotiating argument.
Without a decent diagnose they can mean a real money pittfall which could buy you a much better (younger or bigger) tractor without the worries.
If it was me I would need to have solid reasons (eg as parts donor) to take a tractor with these symptons for FREE.
/ need help
Thanks for the help, I called the seller whom lives 2hrs from me and asked if motor got hot when the clutch went out .
He said it didn't and that it runs but nothing happens in any gear after it warms up. I'm not sure what to think, ??
How can I put a load on engine with a bad clutch?
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63118)
2017 Ford E-Series...
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
2018 Hustler Super 104 Zero Turn Mower (A63116)
2018 Hustler Super...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
