Need help with shed bracing.
/ Need help with shed bracing. #1
JOE G
Eastern NY
Husqvarna / John Deere
Hi, I am going to try and explain this the best I can, I have bracing questions on a shed I am building.
I have an out door pen, it is 20 ft long by 12 ft wide and 8 ft high.
It is built with 6x6 in corners and in the center of the 20 ft runs. I then have a 2x8 all around the bottom top and the middle, this had Weld wire in it for birds.
I now want to enclose it, so I put 4x4 on the bottom and I attached 2 and 9/16th inch thick by 6inch rough cut barn board flooring and I ran them the 12 foot width across.
I I am raising the one 2o ft long end up another two ft with a 2 ft fall I built to get the pitch for the metal roof. I cut in and attached rafters 16 on center for this and I put down 12 x 1 rough cut lumber down as perlins going all the way across every two ft.
The one 12 ft end Id like to open up and make 2 4 ft wide doors.
Outside of the building will be rough cut board and batton.
Any ideas on how I should brace this building, I normally would brace it diagonal on the ends but Id like to open the end up. Its a storage shed but obviously I want it safe
Building is not in concrete as I never planned to do this when i build the run. It is going to be attached to a 10X12 Shed on the one end which I over built and that thing is not moving, 2x6 framed 16 oc walls 5/8th plywood on the outside with board and batton over it, 1/2 plywood on the inside, 2x8 floors with plywood roof same as walls.
I know Pictures would be helpful I just dont have any handy. Thank you
/ Need help with shed bracing. #2
Getting OSB or plywood sheeting on 3 sides would go a long way. If you could only do 2 sides, they should touch at a corner. Then sheet the roof too and tie the roof framing into the walls.
You are looking for terms like shear, moment and the roof would be a diaphragm.
/ Need help with shed bracing. #3
If you can give up some height on your open ends, even a little cross bracing can help a lot. It doesn't have to be all the way down. Also, if you cross brace from the end rafters down to some point on the high side wall, it will give you some support. Yes, pictures would help a lot.
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
(3) Tires (A65640)
(3) Tires (A65640)
Landhonor 3-Pt PTO Potato Harvester (A66285)
Landhonor 3-Pt PTO...
Mini Skid Steer (A60352)
Mini Skid Steer...
