Tractor Sizing Need Help with Right Tractor Size for Property
   / Need Help with Right Tractor Size for Property #11
I too live far away from my country property. I live in Florida and keep a place in central Pennsylvania. He's some considerations for a long-distance relationship with your new Tractor:
Insurance - Add a rider onto your home insurance for the tractor. If it gets stolen or valdalized, the insurance pays.
Keep the tank full - prevents condensation!
Trickle charge the battery - I use a cheap trickle charger when I'm gone for long periods. It works great!
Raise the tractor up on blocks - I put wood blocks under the frame in the winter to raise the tires off the ground. I've been worried about getting flat-spots on the tires when it sits for a few months in cold weather.
Enjoy your new place.... Send pictures!
   / Need Help with Right Tractor Size for Property #12
I'm with Soundguy on size. Get a tractor that will handle 15 foot cutter or you'll spend a whole weekend just cutting 40a and neglecting other chores that pile up with uninhabited property. If a dealer is far, I'd get a rebuilt older tractor without much gagetry that can't be fixed with a wrench. You should be able to find a reconditioned 80-100hp with loader, cutter, blade, whatever tool your heart desires for less than a 45hp new compact ..without attachments. In my area reconditioned JD4020, NH7xxx are around $10-15K. I'd make sure it had synchro transmission, and be wary of powershift type unless you can verify it's rebuilt.
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
1996 John Deere 770 Tractor w/ backhoe
1996 John Deere...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56438)
2019 Krause...
2012 FREIGHTLINER CASCADIA SLEEPER (A59905)
2012 FREIGHTLINER...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A56438)
2010 Doyle 32ft...
