Tractor Sizing Need Help with Right Tractor Size for Property
   / Need Help with Right Tractor Size for Property #11
I too live far away from my country property. I live in Florida and keep a place in central Pennsylvania. He's some considerations for a long-distance relationship with your new Tractor:
Insurance - Add a rider onto your home insurance for the tractor. If it gets stolen or valdalized, the insurance pays.
Keep the tank full - prevents condensation!
Trickle charge the battery - I use a cheap trickle charger when I'm gone for long periods. It works great!
Raise the tractor up on blocks - I put wood blocks under the frame in the winter to raise the tires off the ground. I've been worried about getting flat-spots on the tires when it sits for a few months in cold weather.
Enjoy your new place.... Send pictures!
   / Need Help with Right Tractor Size for Property #12
I'm with Soundguy on size. Get a tractor that will handle 15 foot cutter or you'll spend a whole weekend just cutting 40a and neglecting other chores that pile up with uninhabited property. If a dealer is far, I'd get a rebuilt older tractor without much gagetry that can't be fixed with a wrench. You should be able to find a reconditioned 80-100hp with loader, cutter, blade, whatever tool your heart desires for less than a 45hp new compact ..without attachments. In my area reconditioned JD4020, NH7xxx are around $10-15K. I'd make sure it had synchro transmission, and be wary of powershift type unless you can verify it's rebuilt.
2025 GPS Trailer (A56858)
2025 GPS Trailer...
Sterling 9500 (A56438)
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2013 ISUZU NPR STAKE BODY TRUCK (A59904)
2013 ISUZU NPR...
