Need help with JD Autotrac
   / Need help with JD Autotrac #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
JD 6R 145. I successfully set up a random curve along the edge of a field and it will steer itself along that path. But when I move over to make another pass, I get the message that autotrac has disengage due to being too far off track. I can run straight lines with no problem. What's different about trying to follow a random curve?
   / Need help with JD Autotrac #2
I know nothing about the software but thinking of the problem mathematically I wonder if it has something to do with it being a smaller radius?
Well I finally found some info online and I think I have it figured out, but I'll have to try. Looks like I should be using A-B Curve instead of Adaptive Curve
   / Need help with JD Autotrac #4
I believe you are correct on the A-B curve since that should follow the path you created. Have only used that function once though so memory could be wrong once again.
DIG MASTER DM100 EXCAVATOR (A50459)
DIG MASTER DM100...
2016 Hyundai Equus Sedan (A48082)
2016 Hyundai Equus...
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2 Yard Commercial Dumpster (A49346)
2 Yard Commercial...
Pallet of 22 Misc Wheels (A48837)
Pallet of 22 Misc...
2019 CATERPILLAR 299D2 XHP SKID STEER (A50458)
2019 CATERPILLAR...
