Need help with hydraulic problem
/ Need help with hydraulic problem #1
Anonymous Poster
Epic Contributor
I'm hoping someone can help me diagnose a hydraulic problem. I just got a postdriver that I want to run on my B2710, and I'm completely ignorant about hydraulics.
The postdriver has a single control lever with three positions -- up, neutral, and down. Neutral is the position it stays in if untouched. Because of it's special use, the postdriver has a large diameter return tube that goes directly into the hyrdrauilic reservoir, rather than using a return line with a quck coupler.
Also my tractor is fitted with an extra hydraulic circuit, which was intended to be used for a hydraulic toplink and a cement mixer. It originates at the box at the base of the FEL controller lever. I returned the cement mixer and never got the hydraulic toplink, so I normally keep the two tubes that comprise this circuit connected together with their quick couplers. If the tubes are disconnected, the tractor bogs down.
If I separate the two tubes that comprise the extra circuit, and attach the input line to the postdriver, the tractor does not bog down, so I belive that hydaulic oil is flowing normally. If I push the postdiriver controller lever down -- meaning drop the driver --- the tractor bogs down, but the postdriver doesn't even wiggle. There is room for the postdriver to slide down a little on its tracks. Thereis a safety pin, but I removed it. If I push the lever up, nothing happens at all. In addition, when the postdriver is hooked up, moving the three-point lever has no effect at all. This in of itself witl be a problem if I can't fix it.
Finally, the person who installed the cement mixer told me to use the male end of the extra hydraulic circuit as the input to the postdriver. I believe he was mistaken, as the tractor bogs down in this configuration, regardless of the position of the lever.
Thanks in advance!
/ Need help with hydraulic problem #2
Hi ya
i can't pic how this has been done so i may need some more info
have ya got fatory remotes??if so plug post driver in to one of them making sure ya have the leaver (on tractor !!)in working position so ya use the post drivers hyro bank to do the work..when ya say ya have this extra port connected ya mean in a loop one pluged in to the other?? ..it sounds to me as if it's pumping all the time
ok now post driver is fully lifted?? take ya hoses out of the tractor (warning !!!!!!!!!!!!!!!!! keep people away and watch ya self for what i'm telling ya is not the done thing but will show something)now make both ends open ie take the ends off and SLOWY (READ AS VERY SLOWY!!!)move the lever to lower the ram/hammer/driver oil will come out of one hose that is ya return hose ...i'm thinking it may be plumbed wrong..ok now we have a inlet and return port worked out if hoses wrong swap hoses so big hose is ya dump hose ...i just have a bad feeling that who ever put the extra bank in did not do it right i think it sounds like it's is running all the time where it should be on demand ,i'll think more on this and let ya know ...
catch ya
JD Kid
/ Need help with hydraulic problem #3
Don
How many hoses does your post-driver have? I'm going to assume you only have 2. If that is true, one line that you normally keep connected with hose is pressure. Other line should be connected to return line on your post-driver. By hooking up return line to your return on transmission there is no oil to 3 PH. Hope this helps.
/ Need help with hydraulic problem #4
Don,
First what type of post driver do you have? Next you might be trying to run an open system on a closed system in the hydraulic box on the post driver. Your post driver will either come with an open or a closed system from the factory. You have to hook up your hydraulics based on this. Also make sure you have your driver connections right from the driver itself to the driver hydraulic box.
Hi jdkid,
No factory remotes I'm afraid. I think I'm using the right end of the hose -- I lifted the return line out of the reservoir and I saw a good flow of oil coming out. I guess that means yes, it is pumping all the time.
Come to think of it, when I returned the cement mixer I returned the valve that was supposed to drive it. It had four hoses connected to it. I'm guessing now that if I install one of these valves again I'll be able to use my 3PH again. This hydraulic stuff is starting to come a little clearer now.
Still doesn't explain why the hydraulic flow backs up when I push the postdriver lever down (I can see the hose jerk and the tractor bogs down), but does nothing at all when I push the lever up or leave it in neutral.
It has three hoses, all connected to the postdriver valve. One goes to the hydraulic cylinder which lifts the ram; one goes to the oil reservoir; the third connects to the hydraulic input line.
As I mentioned to jdkid, I'm thinking now that I need to get an extra valve with a diverter so that I can use either the 3PH or the postdriver at any one time. Does this sound right?
Thanks.
The postdriver is a Worksaver HPD16. It ships to run on an open hydraulic system, as is my tractor (it's convertible however).
The connection between the hydraulic box and the driver seems okay. There is oil flowing through into the reservoir.
Thanks
Don
The hoses are hooked up improperly at the valve. The pressure line from your pump needs to go to the port that will deliver flo from the pump to fill the cylinder when you put the handle in lift position. The hose to the reservoir should dump oil from the cylinder when you move the handle to the drop position.
The 3 point ain't working cause your post driver is connected to the hydraulic pressure line and id dumping all oil back to the reservoir.
This diagnosis is based on your description of a single acting cylinder on the post driver.
A diverter valve might solve the problem but shouldn't be necessary. You should be able to use the 3 point by holding the driver valve in the up position with the hammer fully up.
/ Need help with hydraulic problem #9
Don
Attached is an illustration of Hydraulic circuit from the 27-2910 <font color=orange>Kubota</font color=orange> Work Shop Manual. The return line of Post-Driver needs to be hooked up to the second line where FEL valve is hooked to side of tractor. Hope this helps you figure out how to hook up lines.
Hi Ron,
Try scanning @ 400 dpi (or up to 600 dpi and scale the size down) in B/W mode and maybe adjusting the contrast to avoid picking up "page bleed through" {seeing the text on the reverse side}...
This produces a much cleaner and sharper B/W text than using grayscale mode... {then you can only edit in b/w mode not color} /w3tcompact/icons/wink.gif
/ Need help with hydraulic problem #11
Franz,
Geez sometimes the simplest solutions evade us. I hooked up a y diverter on my pounder so I could use the 3 pt. and my pounder.
Thanks Franz, that was a big help. I got the postdriver working today, or i should say I the postdriver started working today under it's own volition. I was testing out what you said by holding the postdriver controller in the up position, then working the 3PH lever to see if the 3PH would move. It didn't, but sure enough the postdriver did. Thereafter it worked regardless of the position the 3PH lever was in (what the...). However, the 3PH still does not work, even with the ram lifted all the way and the lever up.
Do you think I should get a diverter?
Thanks.
After enough years of goin nuts with hydraulic systems, you eventually gain the good sense to go have a mug of coffy and draw the damn thing out on a cardboard box.
The best dirty trick for hooking up hydraulic machines is to run them on compressed air to see what you have to deal with. Air cleans up off the shop floor a lot easier than hydro oil, and 150# of air pressure will usually move most machines without a load on them.
Sometimes you also find the machine is loaded with contaminated oil, and you're a lot happier getting the water/contamination out that way than you will be dealing with frozen hydraulics come cold season.
Glad the suggestion worked out for you.
Remember, keep hand off top of post during hammering operations, hammers hurt!
/ Need help with hydraulic problem #14
Hi ya
yep keep ya hands off the top at all times.get into a habit of holding posts 8-10 inchs from the top with both hands to sight etc some drivers have a chain set up to hold posts while driving use it !!..another thing has ya driver got a driving top ??it's a metal plate setup with wood on the top stops the bounce while driveing and also stops the hammer hitting the top of the post ,it cuts down the amount of cracked post tops .another thing is with the size tractor ya have ya driver on watch moveing it from post to post with the hammer that high of the ground changes ya handling alot
catch ya
JD Kid
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
2022 SANY SY26U EXCAVATOR (A63276)
2022 SANY SY26U...
3147 (A63117)
3147 (A63117)
2013 WYLIE WATER TRAILER (A65643)
2013 WYLIE WATER...
2021 PC210L Komatsu Hydraulic Excavator (A64553)
2021 PC210L...
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
