Need help with governor adjustment on oliver super 55.
   / Need help with governor adjustment on oliver super 55. #1
Biglurr54
Averill Park, NY
Oliver Super 55, 1965 Ford 3400
I just finished up splitting my oliver super 55. I put it all back together and now need to adjust the governor. I read my operators manual and it says to put the throttle at wide open and remove the governor adjuster rod from the governor lever and adjust the governor adjuster rod 1/16 ahead of the hole in the governor lever. It made sense to me until I got in there and the governor lever moved freely. Hard to adjust to 1/16 ahead of the hole when the lever the hole is in can move 4 inches.
Any ideas on how this should be done?
   / Need help with governor adjustment on oliver super 55. #2
Not sure on an Oliver, but the rod they refer to on an IH, is the one from the lever on the Gov. to the carb. On them, there is a threaded yoke you adjust, until the pin just slides through the hole, in the WOT position. That lever is held in position by forks that run against a thrust washer, and from going the other way, a spring holding it to the face of the thrust washer. Looking in the AGCO Parts book at that governor, it basically looks the same, but I don't see a spring to hold it in place. So, could be you need to hold the arm in the direction would be, when at full throttle. That, or you have a problem inside the governor.
It sound similar. The issue is when the gov lever is not attached to the gov rod, it can be moved by hand. How do I know if the lever is in the right spot?
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
John Deere 6175M (A50120)
John Deere 6175M...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
