Need help with front loader lift
/ Need help with front loader lift #1
Qapla
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have a NH TC40D with a NH 16LA Front Loader
The stick to operate the loader is to the right of the seat. Side-to-side movement makes the bucket curl/dump. Forward/Back is the lift operation. It has been working just fine .... until yesterday
Now, when you lift, it will raise the bucket about 2 feet off the ground and stop. If you push the stick back forward, it will lower to the ground just fine. Pull it back and the 2 foot lift then STOP! Curl works just fine.
So far we tried taking one of the lift cylinders off to see if it will extend properly. It will not extend when we use the stick. We also noticed that, if we loosen both of the hoses going to the cylinder, it will spray fluid out of both ends when we move the stick one way, but hardly and fluid out of either end when we move it the other way.
If we disconnect the cylinder completely, we can push it in or pull it our without restriction.
This problem occurred without any warning. One lift it was working fine, the next lift .... STOP
Any ideas?
/ Need help with front loader lift #2
Reset the QD's
/ Need help with front loader lift #3
Yep. In hook and research couplers.
/ Need help with front loader lift #4
Auto-correct issues? LOL
Unhook and reseat the couplers. That fix's 99% of the "my loader won't xxxxx" problems.
/ Need help with front loader lift #6
**** smart phones aint to bright are they:laughing: I think I actually had better grammar and spelling without the autocorrect
Thanks Guys!
When I checked, the bottom QD was, indeed, popped out. It was still sitting in the coupler, but it was not actually plugged in. Plugged it back in and all is good! :thumbsup:
/ Need help with front loader lift #9
Thanks Guys!
Qapla!:thumbsup:
(which means success for those of you that don't speak Klingon)
/ Need help with front loader lift #10
qep誕 cha知aH cha奪Ich
The first actor to speak Klingon wasnt portraying a klingon.at the time, but he was a brilliant engineer . Three guesses as to who he was.
/ Need help with front loader lift #11
qep誕 cha知aH cha奪Ich
Montgomery Scott
Actually, the actor was James Doohan who played Scotty
According to the actor who spoke the lines, Mark Lenard, James Doohan recorded the lines he had written on a tape, and Lenard transcribed the recorded lines in a way he found useful in learning them
So, while James Doohan, the man, not the character Scotty, developed the initial Klingon spoken, it was Mark Lenard, playing a Klingon Captain, who first spoke them "on screen"
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2022 EZ-GO ELITE...
6' ROTARY MOWER (A64280)
6' ROTARY MOWER...
John Deere 1023E (A62177)
John Deere 1023E...
2017 Volkswagon CC Sport Sedan (A61574)
2017 Volkswagon CC...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
