Need Help with Error Message on a 4320
   / Need Help with Error Message on a 4320 #1
m_magpies
Oklahoma
John Deere 4320 2006
I have a JD 4320. After bush hogging for about three hours the malfunction light started to blink. On the display it had an error code of either "cenph1" or "eenph1." I could not find this message/code any where in the owner's manual. Anyone know what this means? After I started the tractor back up the message went away. An hour or so later it came back on again.
   / Need Help with Error Message on a 4320 #2
Highest likley cause is a loose wiring connection. Something snagged a wire connector under the tractor and it is loose. I had this a couple of times on the 4wd engaged sensor.
   / Need Help with Error Message on a 4320 #3
I'm not sure--but don't most (maybe all) of the error codes start err__? Any chance it was sending eeprom messages--only thing I could think of that was close.
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2006 Chevrolet Impala Sedan (A55853)
2006 Chevrolet...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
Unused 20 Ton Hydraulic Bottle Jack (A55787)
Unused 20 Ton...
