need help with BX1500 and BX1800 FEL dimensions
   / need help with BX1500 and BX1800 FEL dimensions
Part of the reason I designed the first quick change the way I did, was because I could hang forks off the top tube, making the quick change double as the structure for the loader assembly.
new loader assembly, roughly 90 lbs, and can carry a little over 700 lbs at 24" out from the pivot pins.
edit - 700 lbs out 24" from the pivots should be way more than the BX's capacity, that's why it's designed so light.
rootrake and grapple. No hydraulics are on it yet, I still need to choose a lightweight inexpensive cylinder. Weight as it is now is about 135 lbs, which is heavier than I wanted, so I need to make some changes.
   / need help with BX1500 and BX1800 FEL dimensions #14
Great looking design !!!
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
Soil Mover Scraper (A50514)
Soil Mover Scraper...
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
PALLET OF CIRCUIT BREAKERS & MISC PIPE (A51244)
PALLET OF CIRCUIT...
