need help with BX1500 and BX1800 FEL dimensions
   / need help with BX1500 and BX1800 FEL dimensions
Part of the reason I designed the first quick change the way I did, was because I could hang forks off the top tube, making the quick change double as the structure for the loader assembly.
new loader assembly, roughly 90 lbs, and can carry a little over 700 lbs at 24" out from the pivot pins.
edit - 700 lbs out 24" from the pivots should be way more than the BX's capacity, that's why it's designed so light.
rootrake and grapple. No hydraulics are on it yet, I still need to choose a lightweight inexpensive cylinder. Weight as it is now is about 135 lbs, which is heavier than I wanted, so I need to make some changes.
   / need help with BX1500 and BX1800 FEL dimensions #14
Great looking design !!!
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2022 JOHN DEERE 26G EXCAVATOR (A51242)
2022 JOHN DEERE...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2006 International 4400 LP Ambulance (A50323)
2006 International...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
John Deere 1790 Planter (A50514)
John Deere 1790...
