Need help with Bobcat 642 axle or bearing problem
   / Need help with Bobcat 642 axle or bearing problem #11
Boy you sure got a good one going on. I think my next step would be checking the drive motor and sprocket. Next the brakes. :confused3: Here is a thought too. If you remove the drive motor for inspection slip off the front chain and run with just the rear. It may point you in the right direction as to where the issue is . front or rear. :thumbsup:
I am trying to think this thing out.....If their were a different link count between the front and rear chains ....would that cause a binding affect after traveling a short distance ??? I think I would be right in saying the chain length needs to be exactly the same on both the front and rear.....I am going pull the four chains out and count the links......and at the same time inspect the drive sprockets mounted on the drive motors......Happy new year to all you folks
Have fun,
buckshot
   / Need help with Bobcat 642 axle or bearing problem #13
Extra length in one chain would not having affect in rotation speed difference of front and rear axle.
Did you remove the drive motor and inspect the spline drive from the motor into center sprocket?
   / Need help with Bobcat 642 axle or bearing problem #14
Have fun,
buckshot
chain links will not change the speed, if you have a loose chain it could ride up on the teeth of the sprocket
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
