Need help with 2-bottom plow idntification
/ Need help with 2-bottom plow idntification #1
ahandmn
I found this old plow against a fence in my pasture and would like to identify it, can you help? Thanks!
/ Need help with 2-bottom plow idntification #2
No clue who makes it but that's a cool find though! Neat old plow, I wonder if the two wheels are original, since one is different than the other??
Wouldn't be even cooler to find more old implements on your place that you didn't know you had?? :)
/ Need help with 2-bottom plow idntification #3
That plow is absolutely complete...as a matter of fact, the front shear(point) looks almost unused. As far as the "two different wheels", that plow has a clutch located in the "studded" wheels hub that raises and lowers the plow as the wheel turns. The clutch is activated by the lever that has the line/rope attached to it. The line was used to allow the tractor operator to pull the rope to lower or raise the plow without getting off the tractor. I'm not sure, but I think that Deere used the "one bolt" plow shares (pls don't hold me to that). I'm pretty sure it isn't an IH due to the rear furrow wheel and the the one bolt shares. Great find!! BobG in VA
/ Need help with 2-bottom plow idntification #4
Interesting... I have this exact same plow. I've used it once and it worked very well. I bought it last summer from a fellow nearby who was hard up for money and he begged me to buy it, so I bought it for around $250.
It's currently sitting in my yard and I don't use it, since I already have a double bottom plow that hooks up to my 3pt.
