Need help wiring a male cap
   / Need help wiring a male cap #1
Chain Bender
Kubota L3200
on a 115/230V Chicago Electric welder. It's cheap, but it's been a great little welder for 10+ years. The power cord out of the machine has 4 wires: brown, black, blue, green. I never bothered to try to wire it for both 115 & 230. I'd like to give it a try, but have no clue which wire goes to which pole.
Please find below the receptacles on my 6500 watt generator. I'm just using them as references. Can someone help me fiure out wich wire goes to which pole on the male cap and what kind of wire(s) would I need to come out of my breaker box and how would I wire them in?
Disregard the 120V/30A picture.
tks,
CB
   / Need help wiring a male cap #2
Quite honestly any 240 volt welder (and 120 volt welder) usually only has 3 wires.
Can you open the welder itself up and see if all 4 wires are connected to something? Im thinking that one of the 4 wires may be capped off.
A 240 volt wire would normally have a black and red hooked up to power and the green hooked up to ground.
A 120 volt welder has a black wired to hot and a white to neutral and green to ground.
On the drawing you have the ground is supposed to be the prong with the twist in it.(labeled #1)
Im really at a loss as to what the 4th wire would be. I 3 phase welder would have 4 wires.....but that would be a major industrial welder.
in the diagram, w= neutral
g=ground
x & y are the hots
   / Need help wiring a male cap #4
His drawing is of his generator, not his welder.
i understand that, but he said his welder has 4 wires. this is whats confusing
all 4 wirews are hooked up.
yellow/green isn't in the picture, but it is ground.
If I am correct I should be able to wire the welder to a 4 prong cap (in previous post) and plug it in to the 120/240 30 amp receptacle of my welder or any other receptacle so wired and be able to switch the machine back and forth between 115 & 230 volts.
Right or wrong?
CB
   / Need help wiring a male cap #6
What is the model number for that welder ?
XXXXXXXXXXXXXXXXXXXXXXX
welder is out inthe shop and it is pouring down rain right now. Will let you know when it slows up a bit.
   / Need help wiring a male cap #8
ive never seen a welder like that one... very strange indeed.
My GUESS at this point without seeing a wiring diagram is the switch is used to swap one of the hot leads (blue or brown ???) with the neutral so the welder can operate on 120 volt. Not sure why one would do this, but without an actual schematic i would not have a clue of how this is wired. I would need to use my voltmeter to check what wire does what. I can t tell by wire color alone to be sure what they did.
i found this on another forum
Blue, brown, black and aqua/yellow wires? Sounds like international color scheme to me. Brown and Black are Phase(hot) colors, blue is neutral and green/yellow is ground. Chicago Electric is cheap Harbor Frieght crap from China. So, that would explain the intl. color coding rather than the black, red, white and green that we are used to. Still, I would be careful hooking it up, because that cheap chinese stuf is notorious for being misswired/labeled.
if this is the case, then the black and brown would go to the x & y terminals of the male plug, the blue would be the neutral (W) wire and the green would be the ground.. So of you wired the male plug like disgramed above, it should work on your generator as you want.
And using the pic of the switch that you supplied, the switch DOES swap between the blue and brown wires, so i think that the post i quoted IS correct, and the blue is the neutral wire.
   / Need help wiring a male cap #10
Your manual.
  • 40388.pdf
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2020 MACK P164T (A58214)
2020 MACK P164T...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2016 Kawasaki Mule (A55973)
2016 Kawasaki Mule...
