Need help wiring a male cap
   / Need help wiring a male cap #1
Chain Bender
Kubota L3200
on a 115/230V Chicago Electric welder. It's cheap, but it's been a great little welder for 10+ years. The power cord out of the machine has 4 wires: brown, black, blue, green. I never bothered to try to wire it for both 115 & 230. I'd like to give it a try, but have no clue which wire goes to which pole.
Please find below the receptacles on my 6500 watt generator. I'm just using them as references. Can someone help me fiure out wich wire goes to which pole on the male cap and what kind of wire(s) would I need to come out of my breaker box and how would I wire them in?
Disregard the 120V/30A picture.
tks,
CB
   / Need help wiring a male cap #2
Quite honestly any 240 volt welder (and 120 volt welder) usually only has 3 wires.
Can you open the welder itself up and see if all 4 wires are connected to something? Im thinking that one of the 4 wires may be capped off.
A 240 volt wire would normally have a black and red hooked up to power and the green hooked up to ground.
A 120 volt welder has a black wired to hot and a white to neutral and green to ground.
On the drawing you have the ground is supposed to be the prong with the twist in it.(labeled #1)
Im really at a loss as to what the 4th wire would be. I 3 phase welder would have 4 wires.....but that would be a major industrial welder.
in the diagram, w= neutral
g=ground
x & y are the hots
   / Need help wiring a male cap #4
His drawing is of his generator, not his welder.
i understand that, but he said his welder has 4 wires. this is whats confusing
all 4 wirews are hooked up.
yellow/green isn't in the picture, but it is ground.
If I am correct I should be able to wire the welder to a 4 prong cap (in previous post) and plug it in to the 120/240 30 amp receptacle of my welder or any other receptacle so wired and be able to switch the machine back and forth between 115 & 230 volts.
Right or wrong?
CB
   / Need help wiring a male cap #6
What is the model number for that welder ?
XXXXXXXXXXXXXXXXXXXXXXX
welder is out inthe shop and it is pouring down rain right now. Will let you know when it slows up a bit.
   / Need help wiring a male cap #8
ive never seen a welder like that one... very strange indeed.
My GUESS at this point without seeing a wiring diagram is the switch is used to swap one of the hot leads (blue or brown ???) with the neutral so the welder can operate on 120 volt. Not sure why one would do this, but without an actual schematic i would not have a clue of how this is wired. I would need to use my voltmeter to check what wire does what. I can t tell by wire color alone to be sure what they did.
i found this on another forum
Blue, brown, black and aqua/yellow wires? Sounds like international color scheme to me. Brown and Black are Phase(hot) colors, blue is neutral and green/yellow is ground. Chicago Electric is cheap Harbor Frieght crap from China. So, that would explain the intl. color coding rather than the black, red, white and green that we are used to. Still, I would be careful hooking it up, because that cheap chinese stuf is notorious for being misswired/labeled.
if this is the case, then the black and brown would go to the x & y terminals of the male plug, the blue would be the neutral (W) wire and the green would be the ground.. So of you wired the male plug like disgramed above, it should work on your generator as you want.
And using the pic of the switch that you supplied, the switch DOES swap between the blue and brown wires, so i think that the post i quoted IS correct, and the blue is the neutral wire.
   / Need help wiring a male cap #10
Your manual.
  • 40388.pdf
Your manual.
XXXXXXXXXXXXXXXX
thanks, Willl. I think we must have found the file about the same time.
115 volt ..............230 volt
ground.............green..................green
neutral.............white
hot..................black L1..............black L1, red L2
tied off wire......red.....................white
only problem with the above chart is that I have a brown and blue wire where the chart and other diagrams mention white and red.
Reminds me of the problem I had with a trailer brake harness several months ago.
Right or wrong?
CB
XXXXXXXXXXXXXX
Just a little more wisdom please.
I would like to just wire the little machine to straight 230 using a 3 wire 12/3. (white,black,green). would someone tell me (using the pictures above) which wires from the new cord I need to swap out with what existing wires (blue,brown,black,green). If I understand everything I think I know, then the male cap would be green/ground and balck/white hot legs. Am I correct?
thanks much,
Chain Bender
   / Need help wiring a male cap #13
Lee you ask hard questions.
Recently When I started a electric project that included a very old electric panel and unusual connectors, I took lots of pictures with the iphone and took the phone to the local friendly electric supply house.
They hooked me up pretty quick and didn't make fun of my lack of knowledge.
Stay dry bro
RC
I agree RC, but I don't have an I-phone or a smart phone. Probably be easier to just pick the welder up and put it in the back of my truck and take it to the store with me.
How's that "dry heat" treatin you out there? It's 95/95 yesterday and today. To hot to take a nap in the shade!
good to hear from you.
Lee
   / Need help wiring a male cap #15
Whats heat? we've had 14 days (of the last 20 days ) of torrential rain. temps in the 40's - 60's.
Today was the first partially clear day in the past week. and it only got to the mid 60's.
we could use some sun and heat.
UNUSED SDLANCH 20'X20' HIGH END CARPORT (A60432)
UNUSED SDLANCH...
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59904)
2019 INTERNATIONAL...
2012 FREIGHTLINER CASCADIC DBL SLEEPER ROAD TRACTO (A60430)
2012 FREIGHTLINER...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
