need help troubleshooting BX-24 Stall
   / need help troubleshooting BX-24 Stall #1
timalabim
Stalls over 2000 RPM. Will start and idle if kept under 2K.
Replaced both fuel filters 2x, drained tank, cleaned, blew out lines.
new fuel, treated fuel. Fuel Pump makes clicks like it's working.
Any suggestions?
   / need help troubleshooting BX-24 Stall #2
Have you checked your air filter.
yes air filter replaced too.
   / need help troubleshooting BX-24 Stall #4
Fuel supply rate issue. Pump going bad, water separator clogged, fuel screen blocked, wax in fuel from cold weather.
   / need help troubleshooting BX-24 Stall #5
Tank vent plugged.
   / need help troubleshooting BX-24 Stall #6
you bled out the fuel lines as well?
   / need help troubleshooting BX-24 Stall #8
I'd take your rear filter off and check it again. You should be able to blow air through it real easy. If not its plugged again. I know you already changed it but they are crap filters, way to small.
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2005 KENWORTH T800 (A50854)
2005 KENWORTH T800...
2020 AMCO F42B-3626CS 13ft Pull-Behind Disc Offset Harrow Tiller (A49461)
2020 AMCO...
New Calf Hut (A50515)
