Need help sizing tractor.
   / Need help sizing tractor. #11
I pretty much concur with all the other advice so far. Sounds like the 4720 and 110 are too small for your purposes - great that you got to find that out without buying one first. I think the 5xxx series from Deere or the Mxxxx series from Kubota are good ones to look at. I own Deere and like it a bit better, but Kubota makes a good tractor also. I think you need to balance the pros of big size with cons - the bigger tractors won't be good in the woods and won't be maneuverable inside smaller pastures (approx. 2 acres but it depends on shape and what you're trying to do).
I own a JD 5105 and think it's a great tractor, but in your case I would be looking at more power, like the JD 5325/5425 or the Kubota M7040 or M8540. I wouldn't jump into the next size class above that (Kubota M95 or Deere 6xxx series) because it will probably be too big for some tasks, and then you have to start looking at buying 2 tractors up front.
I would be looking at 7' medium or heavy duty mowers or maybe 8-10' pull type mowers for your fields.
I have my first tractor and while I didn't want to think about the $$ at the time of purchase, I'm already thinking a cab would have been nice - and I'm only working on 20 acres and in Michigan where the winters aren't as cold. I think you should seriously consider a cab, if you can afford it. The JD 5603 does look like a screaming good deal right now - list price with a 542 FEL is about $49,000, I think, and selling price would hopefully be $45k or a bit less.
If there is a Kioti dealer reasonably close, I think their products are good quality also, and the DK65 with cab would probably be a good deal. It would be at the small end of what I think you should be looking at, though, and it's Kioti's largest tractor right now.
   / Need help sizing tractor. #12
Unless you are going to be in the woods alot I agree with what everyone has said about cabs, well worth the extra money to be out of the sun and away from bugs in summer and snow in winter. As Farmwithjunk has stated the 5603 sounds ideal (he's given me the urge to buy one!!) and dmace's idea on the Kioti 65 might be worth checking out.
   / Need help sizing tractor. #13
A few more Q's - is it a year round homestead? Bias towards new or used equipment? Do you want something to do - the hay renter may already have the capability to maintain the fields, add drainage, etc.. How many hours per week/mo/year do you anticipate working the land?
I agree with your observation that ag equipment is less robust compared to industrial hardware. They are designed for 2 different price points.
A skid steer could be configured to do your tasks, or a mix of ag & industrial if time is a constraint?
   / Need help sizing tractor. #14
I think I would look at used. Big used iron is cheap right now, and you'll more than likely get what you paid for it when you see what you want in a new one! Just a thought.
   / Need help sizing tractor. #15
tractordk said:
Ok, the time has finally come to buy a tractor. I have been watching this site for a few years now and have asked a few questions here and there.
I currently do not have a tractor and desperately need one. I have about 350 total acres in eastern maine. Approximately 120 acres is hay field / pasture, the rest is ponds and woods. The land is relatively flat but does have some hills with moderate grades. Much of the land gets pretty soft for a good portion of the spring / summer.
We currently have someone hay the fields for us 1 time per summer. I don't have any intention of ever haying the fields myself. We do however have to maintain the fields, especially the perimeters with a bush hog.
I am interested in the following attachments immediately:
a moderately sized medium/heavy duty bush hog for field maintance
chipper for chipping 6 inch and smaller trees
FEL for moving dirt/rocks, etc
grapple for FEL for general pickup, digging up roots, etc
backhoe for planting trees, pulling stumps, digging drainage ditches, etc
Basically I need a general purpose tool to help me with everything around the yard from pullings stumps, maintaing roads and fields, etc.
I am tentatively looking at a JD 4720, 110 TLB or a 5025 series. The only tractor dealer that is relatively local (an hour drive) is JD.
I love the idea of having a cab, but don't need it.
I had a 110 TLB on our property for a couple weeks 2 years ago and loved the machine, it just seemed a bit small for working in the fields. It also seemed to get stuck more often than I would like. I have a HD pickup with a large winch so I can pull things out easily, but its a pain to have to do often.
I just rented a 4720 with FEL and 5' heavy duty bush hog for 2 days. I thought the machine was nice but seemed a bit "light duty" We moved some rocks and heavy clay with the FEL and the FEL seemed to flex an awful lot. Also with a load of clay the FEL's hydraulic strength seemed inadequate - i was unable to do 2 functions at once. I was also suprised it wasnt more powerful. It couldn't maintain speed in the C range when going up hills from one work site to another - even on paved road caring only the bush hog and empty loader. I have pretty much ruled out the 4720, it just seems like its not designed for the heavy duty work i have in mind.
My biggest concern is HP and transmissions. I love the hydro transmission, but it seems the only machine that is beafy enough to do the loader work i want to do that has hydro is the TLB. Unfortunately the TLB seems pretty small for field work. So I really don't know what to do.
Any thoughts/advice/etc would be very very much appreciated. Please feel free to ask questions if i can do anything to clarify my needs / terrain.
Thanks so much in advance,
Ben
You may have a problem finding one tractor to handle all your requirements satisfactorily. You say that the TLB you drove seemed too small for handling your field chores. That should be the clue telling you to think about two tractors: a small utility tractor with hydrostatic transmisssion and 4WD (30-50hp engine) set up as a TLB; and a 100+ hp (engine) ag tractor set up to handle your large field maintenance implements.
I would check eBay for pre-owned tractors dating from the 80s or more recently with under 5000 hours.
   / Need help sizing tractor. #16
RoyJackson said:
Farmwithjunk is pointing you in the right direction, Ben...
Whoa! Maybe I am, Maybe not, but this much is for sure Roy, Now I need to go rest my eye's for a bit. Those emboldened letters just about sent me into a state of shock! ;)
Thanks for the vote of confidence anyway!
Hi,
Wow! lots of information to look through. Thank you all.
I spent the day in the yard working on a garden and contemplating my tractor tasks and needs. I think that the 2 tractor idea may be a good one. Possibly something in the 3720 range and another at the large end of the 5000 series.
I plan to look everyones replies over more thoroughly this evening and spend a some time thinking about this. I have two friends turning 30 today so have to take a little break from thinking about tractors. Ill be back on it later tonight.
Thank you all again,
Ben
BarryinMN,
It is a year round homestead for now. It is likely that we may not spend much of the winters here, but certainly some.
I would like to go with new or nearly new equipment. We are a good distance from shops/dealers so I want to minimize mechanical problems.
Unfortunately our hay renter has been unwilling or unable to do any maintance for the previous 5 years - so i am giving up on that for now. We have had the same issue with our previous hay renters as well. It seems that we will need to maintain the fields to keep them in the condition we want.
Thanks,
Ben
   / Need help sizing tractor. #19
Yes, I've recently discovered the Bold and Font size buttons..I'm very happy now.
   / Need help sizing tractor. #20
Sorry for all the Q's but your wide variety of tasks is a candidate for multiple machines.
A skidsteer is low profile enough to squirt under overhanging tree branches around field edges, hydrostatic, cab heat A/C, all-wheel or track drive, and the big advantage - you can see the tool front edge and exactly what is going on. Tractors have that nose that gets in the way - large or small..
Anyway, a 5000 series Deere per FWJ makes sense and has a lot of flexibility. A cab has the option of a jump seat with seatbelt for taking helpers along. Just account for the infrastructure to support it - storage, fuel, normal maintenance, a method to haul it if needed, (dealer might include transport for warranty repair on the little guys - not the utilities & up).
An 8' bush hog might be a little small, a 10-15' will give you more reach along fencelines and field edges outside the rear tire wheel base.
Keep us posted on your deliberations.
Stout Brush Grapple (A59814)
Stout Brush...
Ryan Walk Behind Aerator (A59228)
Ryan Walk Behind...
Attention (A57148)
Attention (A57148)
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
flatbed trailer 24ft (A56857)
flatbed trailer...
