Need help selecting spool valve
/ Need help selecting spool valve #1
carowby
Northcentral PA
Kubota BX2200
I have ordered parts to install rear hydraulics on my BX2200 using information from this post;
http://www.tractorbynet.com/forums/kubota-owning-operating/14585-added-rear-hydraulics-bx2200.html
I am planning to put a hydraulic cylinder on a pull behind disc that I use for food plots, and would also like to add a hydraulic top link. I have been looking through Surplus Centers vast supply of spool valves, however with a very limited knowledge of hydraulics, I am not sure what would be best to use with this set-up.
Any help would be greatly appreciated.
Thanks,
Scott
/ Need help selecting spool valve #2
If you do a search on spool valve or rear remote you'll get lots of info. Here's a thread I posted when I picked mine that might help you:
Spool Valve
/ Need help selecting spool valve #3
Do you want to be able to adjust your disc and your top link at the same time or will it be a one or the other setup?
Big things to consider is matching the GPM of the valve to your system and choosing a layout of ports and lever(s) that you can work with mounting it. Depending on how much of a fabricator you are, you can mount it out of the way and run a lever to someplace you can easily reach.
I will only be using one at a time for now, however I would like to install a 2 spool valve for future use if that will work.
The BX2200 has a 4.5 GPM system.
The plan is to mount the valve to the ROPS, fabrication should not be a problem.
Thanks,
Scott
Landhonor Quick Attach Power Rake (A66408)
Landhonor Quick...
19-gallon Portable Sandblasting Cabinet (A66408)
19-gallon Portable...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
2011 OVERLAND TANK 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 OVERLAND TANK...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
Cute Electric Car (A62679)
Cute Electric Car...
