Need help selecting spool valve
/ Need help selecting spool valve #1
carowby
Northcentral PA
Kubota BX2200
I have ordered parts to install rear hydraulics on my BX2200 using information from this post;
http://www.tractorbynet.com/forums/kubota-owning-operating/14585-added-rear-hydraulics-bx2200.html
I am planning to put a hydraulic cylinder on a pull behind disc that I use for food plots, and would also like to add a hydraulic top link. I have been looking through Surplus Centers vast supply of spool valves, however with a very limited knowledge of hydraulics, I am not sure what would be best to use with this set-up.
Any help would be greatly appreciated.
Thanks,
Scott
/ Need help selecting spool valve #2
If you do a search on spool valve or rear remote you'll get lots of info. Here's a thread I posted when I picked mine that might help you:
Spool Valve
/ Need help selecting spool valve #3
Do you want to be able to adjust your disc and your top link at the same time or will it be a one or the other setup?
Big things to consider is matching the GPM of the valve to your system and choosing a layout of ports and lever(s) that you can work with mounting it. Depending on how much of a fabricator you are, you can mount it out of the way and run a lever to someplace you can easily reach.
I will only be using one at a time for now, however I would like to install a 2 spool valve for future use if that will work.
The BX2200 has a 4.5 GPM system.
The plan is to mount the valve to the ROPS, fabrication should not be a problem.
Thanks,
Scott
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
1979 Donahue Dump Trailer (A66285)
1979 Donahue Dump...
(2) 27x32 CIH Rims (A65640)
(2) 27x32 CIH Rims...
Palp Cage for Chute (A66408)
Palp Cage for...
Steel Coils (A65640)
