Need help rebuild little control valve
   / Need help rebuild little control valve #11
Most spool valves do not have "seals", the use very close tolerances between the valve body and the spool. The best you can do at this point is to polish the spool to remove the rust.
   / Need help rebuild little control valve #12
helpful tips.
   / Need help rebuild little control valve #13
Regluar spool valves like mono block valves and stack valves DO have spool seals between outside and the return core, to prevent external leakage from the low pressure return core...
If spool valve are built into tractor transmission etc, no seals needed if oil leaks to the sump....
   / Need help rebuild little control valve #14
Thought I was alone thinking this....:thumbsup:
I didn't find anything that looked like a seal or "o" ring. Again, this is an antique and the installation instructions say some "small drops of oil" is normal. Here is the disassembled valve. I'm trying to locate the two small "return" springs. We don't have a local hardware store, so shopping for them when I'm visiting towns that do.
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
