NEED HELP PLEASE!
   / NEED HELP PLEASE! #1
edon100
Doniphan,MO
Kioti DK35,1947 Ford 8N,Bolens 1257,Husqvarna Lawn Mower
I need some expert advise on how to fix my 1947 Ford- How to change electrical from 6 volt to 12 volt negative ground.
   / NEED HELP PLEASE! #2
all u have to do is change the coil, the soleniod and the generator to a altenator
   / NEED HELP PLEASE! #3
Haven't seen much about this in the New Holland Forum over the past 10 years. I would suggest Yesterday's Tractors for help.
   / NEED HELP PLEASE! #4
There IS an antique ford section her at TBN
if this is a 47 ford 8n we are talking about.. it's nothing more than swapping the genny for an alternator and the brackets to do so, upgrading to a 2.5 ohm coil, and keeping the oem ballast resistor, adding a 12v battery, and makeing sure you are negative ground.
OEM 6v starter and solenoid DO NOT need to be changed.
this is an easy common changeover.
if you like you can even have the old 6v genny rebuilt as 12v, get a new vreg and the battery/coil and keep it looking original.
soundguy
   / NEED HELP PLEASE!
Thank you all for your help:thumbsup:
   / NEED HELP PLEASE! #6
post back if yhou hit any bumps in the road.
soundguy
   / NEED HELP PLEASE! #7
Just a curious bystander question, don't the bulbs need to be changed?
   / NEED HELP PLEASE! #8
you SHOULD change them.. but i know some that simply wire them in series till 1 fails, etc.
soundguy
   / NEED HELP PLEASE! #9
There are many of these tractors that have had their lights removed for many years. Changing to 12 volt lights is certainly recommended if you need them. In the case of my NAA many years ago, I went out and bought some shiny chrome offroad lights and mounted them in place of the factory lights while retaining the oem parts. Except for testing the new fancy lights for operation, I don't think I ever used them once.:)
   / NEED HELP PLEASE! #10
My neighbor bought a kit from the local New Holland/Ford dealer. It included a rebuilt alternator, all the parts, brackets, bolts, a new fan belt and complete instructions.
I'm thinking it was $140-150??
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2016 Chevrolet...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2021 New Holland C327 Compact Track Loader (A53473)
2021 New Holland...
