Need Help Please, Gravely Blower Clutch
   / Need Help Please, Gravely Blower Clutch #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I am baffled! I was using my professional 12, and a quick attach non-square
blower. It is a two stage blower, with the whole drum that turns to determine blowing direction. I have not used this thing for a while, and wanted to blow the snow away from around the house, before the impending thaw. I just got chains for it, and new rubber!
Man was it blowing snow! Brought a smile to my face, and that doesn't happen all too often! Then in the thidk of it, the auger quit, while the impeller kept going. I cleared it out and can't understand what I am observing. The auger started working again! Yes, I read something about a clutch, in another post, and this is what I suspected. But when I jam one auger, I can see something just a little smaller then the diameter of the Auger tube, spinning, ON BOTH SIDES! And both sides stop, when one side is jammed!
Can someone explain this magic to me, and what I can do to fix, the situation, that the auger won't move much snow, before stopping! It was working just great, and maybe I overdid things a bit!
Also, the tire chains work awesome, even though they chew up the grass. They are sloppy, and I wonder how tight they should be? On one side, the sloppiness is threatening the brake mechanism.
Also, I am going to have to do something about putting counterweight
on the rear, because it takes just about al my weight (200 LBS) to keep the front of the blower from digging into the unfrozed ground. Any suggestions? I was going to have a friend laser cut out some 1/2 plates to bolt onto the rear, but ideally, the weight should hang out, good and far. Any body else done anything like this?
Thanks for the help!
   / Need Help Please, Gravely Blower Clutch #2
Might want to take a trip over to OldGravelys.Net: : , there are many parts and service manuals available for the tractor and attachments. A set of casters, available on ebay from time to time would work nice, I have them on my sq shoot blower, I don't have to manhandle the machine at all. Lets me use the blower on grass without tearing it up, or on gravel without eating it.
Thanks so much! I got exactly the information I needed.
Sometimes technology can work!
Still curious about the sloppiness of the tire chains?
   / Need Help Please, Gravely Blower Clutch #4
If you want tight chains deflate the tire, put the chains on snug reinflate the tire and put tensioners on them. Might have to do it a few times to get it just right. I don't have the brake option on mine so I don't know how much clearance were talking about.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2019 John Deere 3025E (A50123)
2019 John Deere...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
