Need help picking correct oil for my 25 year old 19hp twin Generac generator
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #51
Disregard forgot this was already beat to death.
90cummins
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #52
OP: have you contacted Generac central on oil question?
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #53
Valvoline racing oil is very high zinc. I run a 30 wt. (5w or 15w depending where in the country you are). I have a 26kw Generac.
Sorry I missed this but no, I have not called Generac. I'll get a standard answer that I of don't deviate and all current oils are back-certified,, etc.
I did't see the need to after I found that old style higher ZDDP oil is now made for "off-road" use. I changed oi, used that and feel I'm either good or good enough. Again, sorry I missed your reply. 🍻
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #55
The mills I maintained ran on big Cat gensets. The last one was a 1000HP 3512. All maintenance was scheduled on fuel consumption, not hours or dates. Makes good sense when you think about it. In 1998 I started using a Honda GX4 water pump to transfer water to…well that is really another story. I rigged a 6 gallon tank from an old portable generator to let it run continuously. The motor runs at 1/4 throttle. A full tank would run it for about 6o hours. I change the oil every four tanks, figure 50 gallons because I usually don’t let it run it of fuel. That is about 200 hours of run time. I use the cheapest 10-30 syn-blend I can buy, usually from Walmart but I have used Amazon basic as well. I put another 70 gallons of fuel through it this year, so far. The motor seems a bit down on compression and has started to use a little oil. Still starts on the first pull. I wrote to Honda to share my experience, but never got a reply. By my cocktail napkin calculation using 600 hours a year I now have in the neighborhood of 15,600 hours on a splash lubricated single cylinder air cooled engine (though since it’s a water pump there may be some additional cooling). My point is that oil levels, and oil changes are what is important. If your piece of mind requires a particular brand of oil, then that is what you should use. I use T6 10-40 in all my diesel engines. Mobil 1 5-30 in my pickup. And the 10-30 syn-blend in my gas powered mowers. So far, so good.
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #56
I used Mobil 1 5w30 for my Generac 17kw generator. At one point I bought some Traveler synth. 5w30 from TSC to save a few bucks. Put that in and it ended up burning off half a quart in 100 hours. I could smell it when it was running. Switched back to Mobil 1 and no more burn off or smell. Choose wisely.
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #57
Generac specifically says….no additives in oil. They told me to not use a zinc based breakin oil on new engine.
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #58
I run Shell Rotella 15w40 in every aur cooled engine I own. In 35 years I have had 0 issues and the only engine I have had any issues with involved a nephew and running upside down. But that's a whole different story. Diesel engine oil has all the specs you need and will keep it cleaner.
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #59
For those wanting high ZDDP, Motorcraft Heavy Duty oil is the ticket: I use this in my 94 Cummins, 2013 Yanmar 3 cly in my Polaris, my 94 Kubota generator, my 2006 B7800 and my ALH TDI; it specs identically to the previous generation Shell Rotella T6, the CJ-4 spec (now CK spec).
   / Need help picking correct oil for my 25 year old 19hp twin Generac generator #60
I read that Generac only makes RV generators now. And
Briggs & Straton has the others
willy
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2020 John Deere 6195R (A50120)
2020 John Deere...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
1981 FMC Link Belt Crane (A50120)
1981 FMC Link Belt...
Caterpillar 304 ECR (A50120)
Caterpillar 304...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
